Tascam m-208 mixer with problem
  • tmhobadcap
    • Apr 2019
    • 146
    • CANADA
    I got this mixer for free and is trying to see if I can fix it.
    The problem is when it is switched on, the lights just turn on for half a second and then nothing.
    Instead of asking directly how to fix it, I would like to first try using my limited knowledge to fix it myself. Of course, I need your helps in some ways.
    I suspect it is the power supply problem. Visually, there is nothing wrong on the power supply board. I am trying to find out which component is causing the problem. From the incoming AC power, I found that there is a component (as shown on photo) connecting between the black line and the line to the input of the transformer. According to the service manual, it is "Z001, CR, 0.033uF+120 125V". What exactly is this component? Can it be tested with a multimeter?
  • petehall347
    • Jan 2015
    • 4425
    • United Kingdom
    Re: Tascam m-208 mixer with problem
    safety capacitor .
    • tmhobadcap
      • Apr 2019
      • 146
      • CANADA
      safety capacitor .
      Thank you! Should I just test it like a regular capacitor?
      • petehall347
        • Jan 2015
        • 4425
        • United Kingdom
        it is not your problem .it goes across the power switch .
        more likely a loose or corroded fuse or bad power switch . start by checking AC voltages at the fuses .
        power for the lights and more comes from power supply pin 17 yellow wire .
          • 30951
          it's not exactly a capacitor,
          it's a snubber - a capacitor and resistor in series.
          but as said, it's not the problem.
          maybe the switch has a bad contact, always good to start at the begining.
          • tmhobadcap
            • Apr 2019
            • 146
            • CANADA
            Thanks for petehall347 and stj's suggestions.
            My checking results are as follows:
            Power Switch - Checked and cleaned the contact.
            Got input and output voltages from the transforma.
            Fuses - checked and no problem
            Checked the Power Supply PCB - no visible damaged components, re-weld some of the suspected poor welded joints, but problem still exist.
            Output voltages from power supply board - Yellow wire (pin 17) is 6V, Blue wire (pin 16) is -15V, Red wire (pin 14) is 15V - all matching the voltages printed on the Meter PCB
            Any more suggestions for me?
            • petehall347
              • Jan 2015
              • 4425
              • United Kingdom
              have you checked to see if its actually working yet ?
                • 30951
                when you checked those voltages, where did you put the black wire - 0v, or ground?
                you need to have it on 0v
                • tmhobadcap
                  • Apr 2019
                  • 146
                  • CANADA
                  I just checked that it is not working.
                  • tmhobadcap
                    • Apr 2019
                    • 146
                    • CANADA
                    Yes, when I checked those voltages, I put the black wire to the 0V.
                    • petehall347
                      • Jan 2015
                      • 4425
                      • United Kingdom
                      i would start pulling plugs and squirting contact cleaner in them .and looking for dry solder joints
                      • budwich
                        • Jul 2015
                        • 3097
                        Although you have checked the THREE voltages listed, you have not indicated what the voltages are back in the first post for FOUR fused positions / outputs in the first post. What is the "fourth"?
                        • petehall347
                          • Jan 2015
                          • 4425
                          • United Kingdom
                          pins 18 and 20 are the missing ones i reckon .. think that's headphone amp supply .
                          being as the lights are trying to give a clue maybe best see why they aren't working first .
                          • tmhobadcap
                            • Apr 2019
                            • 146
                            • CANADA
                            Pin 8 (F001) = 19.5V
                            Pin 9 (F002) = 19.5V
                            Pin 11 (F003) = 9.5V
                            Pin 12 (F004) = 9.5V
                            Sorry, I do not understand what do you mean by the "fourth".
                            • tmhobadcap
                              • Apr 2019
                              • 146
                              • CANADA
                              Pin 18 = 11.4V
                              Pin 20 = -11.4V
                              • tmhobadcap
                                • Apr 2019
                                • 146
                                • CANADA
                                For me, this will take a lot of time, so I will leave this as the last job.
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  🛠 Original Issue
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • Technomancer
                                  Nintendo 2DS SD Card Reader issue. Problem on the clock line?
                                  by Technomancer
                                  I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
                                  Here is what I have done so far:
                                  -Tried SD card in another 2DS and on PC, works great.
                                  -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
                                  -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
                                  06-07-2022, 09:01 PM
                                • Felipe_Serra_83
                                  US Audio Mix-8 Line Mixer - Tº while idle
                                  by Felipe_Serra_83
                                  Hello all.
                                  I have a US Audio Mix-8 Line Mixer, rack mountable. I changed the fuse and powered on with a current limiter (lightbulb thingy).
                                  I noticed that the voltage regulators (could be 7818-7918 - not sure because the heatsinks covers them) get hot, even though I'm not connecting lines in nor speakers. They get up to 52ºC in a couple of minutes after powering on.
                                  My question: is this normal? My gut tells me it isn't, and I'm thinking about some faulty component pulling too much current. But I have investigated and can't find nothing.
                                  Thanks...
                                  09-06-2024, 11:32 AM
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • FALKLAN
                                  Running Line Voltage and Integrating LED Pods - Automotive
                                  by FALKLAN
                                  Howdy everyone! I hope all is well where ever you are!
                                  I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                  I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                  02-05-2025, 12:30 AM
