US Audio Mix-8 Line Mixer - Tº while idle
  • Felipe_Serra_83
    • Nov 2023
    • 25
    • Chile
    Hello all.
    I have a US Audio Mix-8 Line Mixer, rack mountable. I changed the fuse and powered on with a current limiter (lightbulb thingy).
    I noticed that the voltage regulators (could be 7818-7918 - not sure because the heatsinks covers them) get hot, even though I'm not connecting lines in nor speakers. They get up to 52ºC in a couple of minutes after powering on.
    My question: is this normal? My gut tells me it isn't, and I'm thinking about some faulty component pulling too much current. But I have investigated and can't find nothing.
    Thanks in advance for any help in this.
  • Bektronics
    Schematic Digital Audio mixer RCF type M18
    by Bektronics
    Hello dear audio friends.
    I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
    The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
    I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
    Thanks in advance if anyone can help me with this schematic.
    Of course, all information about this digital mixer and possibly references...
    07-24-2023, 06:40 AM
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • kotel studios
    Lantec PULSE 386 subwoofer - no audio output
    by kotel studios
    Hi
    I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
    After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
    The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
    11-29-2025, 04:15 AM
  • FALKLAN
    Running Line Voltage and Integrating LED Pods - Automotive
    by FALKLAN
    Howdy everyone! I hope all is well where ever you are!
    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
    02-05-2025, 12:30 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
