Double Din Car Headunit Brand Unknown
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Not something I have ever attempted before, but knowing I dabble with TVs, a friend of mine asked me to have a look at this for him.
    I dont know what brand it is, think its just some cheap chinese generic rubbish
    Someone has apparently bought it brand new, wired it up wrong somehow, blew fuse on unit, fuse in car, amd said it smoked slightly and could smell it.
    Replaced fuse, but no signs of life, is there anything I can do or is it just fit for the scrap?
    Wouldnt know where to start personally so any help grately appreciated.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Double Din Car Headunit Brand Unknown
    have you removed the pcb and checked if there is any trace damage on the underside of the pcb
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      I havnt mate as yet, all ive done is open it up to take pics, ill do that next and report back
        • 31255
        if you call that well serviceable device crap, you obviously have not seen inside the italian shit the car makers fit.
        • R_J
          • 9607
          Seems to be a Xtrons pb86mtvap, There is a diode D2? near the fuse, have you checked it? Check the resistance between ground and power input.
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Your right, I havnt lol, as I say, Ive never opened one up before, never had to until now
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              Ill have a look when im home, I litterally just opened it up and took a few snaps when I had 5 mins spare earlier, havnt done anything else as yet
              • Bloopeta
                • Jun 2018
                • 526
                • United Kingdom
                Heres a pic of the underside, looks ok to me, but im no expert
                • vinceroger69
                  • Mar 2012
                  • 6714
                  yes underside looks fine time too check what r_j suggests now
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    On with that now m8, I think the diode is goosed, am I best off taking it out of the board to test incase pf false positives?
                    • R_J
                      • 9607
                      Many times they use a diode across the 14 volt input for protection, If you supply reversed voltage, the diode conducts and blows the fuse, or in some cases the fuse will also short. You may get lucky and it's only a shorted diode.
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Was exactly that, thankyou very much for your help, and to everyone who replied, much appreciated
                        • R_J
                          • 9607
                          Good to here its working, make sure you replaced the diode for continued protection.
                          • Bloopeta
                            • Jun 2018
                            • 526
                            • United Kingdom
                            Yeah replaced it with an exact match as my friend who it belongs to had a spare unit with a broken screen, so took it out of that.
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • jesterace
                              Samsung UE46ES8000 Blown fuse but no other signs of short
                              by jesterace
                              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                              09-11-2024, 03:14 PM
                            • Acnologia
                              Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                              by Acnologia
                              Here is a pretty crazy one.
                              Step 1.
                              Laptop was brought to me as dead not working. Removed everything , cleared everything.
                              Step 2.
                              Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                              Step 3.
                              Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                              Step 4.
                              Lets ,dive into the board. I see the edp cable on the...
                              05-07-2025, 07:16 AM
                            • Stanley1843
                              BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                              by Stanley1843
                              has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                              06-22-2024, 11:06 AM
                            • jshhh
                              Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                              by jshhh
                              Hi guys,
                              I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                              How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                              Anybody know how to remove this type of fuse?
                              (The fuse is toward the bottom of the image labeled F2)...
                              06-17-2025, 01:35 AM
