Dewalt DC012 Shop Radio no Sound
  • henryvrensburg
    • Oct 2018
    • 104
    HI guys
    I am a total rookie when it comes to sound equipment, but have some limited electronics knowledge. I have a Dewalt DC012 Shop radio. The radio switch on, change channels, even search for radio channels, but it's got no sound. Nothing from the speakers. Both the speakers measures 5.8ohms.
    DO you have any idea what I can look for
    Re: Dewalt DC012 Shop Radio no Sound
    Start by upload good clear outside and inside pictures so we can see what we are dealing with.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      try plugging into aux .
      • henryvrensburg
        • Oct 2018
        • 104
        Hi guys
        Im sorry for the long time delay. Please find herewith pictures of the Power supply board and I think Sound board. The only voltages I could measure was on CN508.
        If ground is ground in Connector, then the 13V measured as 16.5V and the AC Det. as 9.86V.
        Thank you
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          shorted caps near the amp chip
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            did you try aux in yet ?
            • henryvrensburg
              • Oct 2018
              • 104
              Hi guys,
              Thank you for your help. I could fix my Shop Radio. I found one 470mF cap close tot the AMP chip, replaced it and now my Radio is working again.
              Thanks again
                • Jul 2011
                • 6040
                I would recommend that you replace all the capacitors
                Especially if they are non brand capacitors
                • kmssd
                  • Jun 2016
                  • North America
                  What chip is the amp? I have a similar problem, except the volume is very low at full volume.
                    • 31067
                    amp is under the aluninium plate that looks like wings
                    • kmssd
                      • Jun 2016
                      • North America
                      Thanks, I'll have a look through my radio.
                        https://www.badcaps.net/forum/attach...4&d=1581186515
                        Verify that you do have Voltages feeding that black connector CN508, also show us the pin names for the CN508.
                        • gilhurt
                          • Oct 2020
                          Hi, I have the same DC012, no sound. Measured the output voltage of the power pcb assy (which feeds the radio pcb), supposed to be 13V, reads 16V (circled in orange).
                          Could this 3V prevent the radio board to function properly?
                          The visual check does not show anything damaged or burnt on all pcbs, except for the resistor (circle in red) where the pcb changed color. The color bars indicates a 15 ohms resistor which reads good. The two blue relays on the left get pretty hot too.
                          Thank's
                          Gilles
                          • gilhurt
                            • Oct 2020
                            Ok, thank's to everyone. Project closed, radio sent to recycling center. Gilles
                            • Sushi1808
                              Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
                              by Sushi1808
                              Hi everyone!
                              I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
                              I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
                              There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
                              07-01-2023, 07:53 AM
                            • shelby5041
                              clock radio / radio lifespan?
                              by shelby5041
                              hi
                              ive got a modern digital clock radio approx 15yrs old
                              my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                              since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                              the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                              it uses very little power just a few watts i would imagine that may have something...
                              09-14-2024, 03:30 AM
                            • elviscen
                              Car auto radio Alpine CDE-170R no sound
                              by elviscen
                              Hi to all,
                              Anyone have some advice what can be wrong if Car auto radio Alpine CDE-170R have no sound output?
                              All works fine, mute disabled, also change cables, ...
                              I connect it on my bench and connect new speakers, all setup on the Auto radio are correctly setup-ed, just no sound output.
                              Inside nothing burned.
                              Any advice what can be wrong?
                              Anyone have boardview and schematics for this Car radio Alpine CDE-170R?
                              Thank you.
                              Best regards,
                              Elvis C.
                              04-21-2022, 07:40 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • praveenramavath
                              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                              by praveenramavath
                              Hello All,
                              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                              https://www.hifivision.com/threads/m...-screen.98243/
                              Troubleshooting Summary: Majority Internet Radio - Flash Chip
                              04-26-2025, 09:08 AM
