Car auto radio Alpine CDE-170R no sound
  • elviscen
    • Apr 2022
    • 8
    • Slovenia
    Hi to all,
    Anyone have some advice what can be wrong if Car auto radio Alpine CDE-170R have no sound output?
    All works fine, mute disabled, also change cables, ...
    I connect it on my bench and connect new speakers, all setup on the Auto radio are correctly setup-ed, just no sound output.
    Inside nothing burned.
    Any advice what can be wrong?
    Anyone have boardview and schematics for this Car radio Alpine CDE-170R?
    Thank you.
    Best regards,
    Elvis C.
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Re: Car auto radio Alpine CDE-170R no sound
    Check the menu for POWER IC, it is disabled by default.
    Connecting to an external amplifier
    (POWER IC)
    If an external amplifier is connected, the sound quality can be
    improve by turning off the power of the built-in amplifier.
     Setting item: POWER IC
    Values:
    OFF / ON (Initial setting)
    OFF:
    Use this mode when the line output of this
    device is used to connect to an external
    amplifier. When using this setting, the internal
    the main unit amplifier turns OFF and does not affect the
    dynamics.
    ON:
    The speakers are connected to the built-in amplifier.
    OF
    • Sushi1808
      Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
      by Sushi1808
      Hi everyone!
      I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
      I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
      There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
      07-01-2023, 07:53 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • UserXP
      Mackie CR4 amplifier no sound
      by UserXP
      Hi, people.
      I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
      Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
      10-17-2020, 05:06 PM
    • shelby5041
      clock radio / radio lifespan?
      by shelby5041
      hi
      ive got a modern digital clock radio approx 15yrs old
      my question is how long can a clock radio or a simple radio last ss farcas operating hours?
      since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
      the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
      it uses very little power just a few watts i would imagine that may have something...
      09-14-2024, 03:30 AM
    • eduaqa
      Amplifier - bad sound when loud sound on bass
      by eduaqa
      I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
      I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
      08-06-2022, 11:28 AM
