PC Speakers Changing Volume
  • conglo
    • Aug 2009
    • 17
    I have a Cambridge Soundworks FPS2000 PC speaker system. It's a standard 4.0 + subwoofer setup.
    Sometimes the volume changes. I can't reproduce it when I want; it randomly happens. It seems to be a drop in volume and them it will randomly go back up in volume at any later time.
    The volume levels don't seem to change. The lower volume always sounds the same and when it goes back up, it sounds the same. So, the volume levels aren't random, but the amount of level drop seems to be consistent.
    What would cause this? Bad Caps?
    Do you think this is something that is fixable?
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: PC Speakers Changing Volume
    Thanks.
    It's almost certainly NOT related to caps. Two things seem most likely; the volume control (if it uses a mechanical (potentiometer)) volume control, or a poor connection to the sound card.
    PlainBill
    • conglo
      • Aug 2009
      • 17
      The cables feel pretty solid, but I may buy new ones.
      As for the volume control...
      There is a mechanical pot in it. I never use it though. Could it just "go bad" if it is untouched? Of course, I did touch it when I first noticed this problem.
      One other thing that I think it could be...
      I've unplugged the audio cable without first turning off the speakers and it made hums and pops. Would that break anything?
      Thanks.
      • Krankshaft
        • Jan 2007
        • 2328
        That depends if the volume control is simply a voltage divider and DC applied to a terminal of an IC controls the volume. It may be due to a temporary swing in supply voltage.
        Be sure to check your audio source first though.
        • conglo
          • Aug 2009
          • 17
          The audio source is good. I've tried with three different sound cards and they all do the same thing. Then, thinking it was my computer, I tried it with a portable MP3 player and I got the same results.
          I figured it must be the speakers.
          • kikkoman
            • Jul 2007
            • 691
            my creative surround speakers did that too after a while (and i barely used the volume control.)
            the poti in the cable remote control was a really shitty one. a pencil and some grease fixed it for a while, i didn't bother to find replacement pot
            since creative builts parts of these cambridge sets you might have the same issue.
            "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
            • lucky13
              • Aug 2007
              • 412
              Thanks.
              Well, if you turn the pot and the sound is scratchy when you are turning it, then it is the pot.
              • conglo
                • Aug 2009
                • 17
                The sound isn't scratchy when I turn the pot.
                Does this positively eliminate the pot?
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Not if the POT isn't controlling the audio output directly if it's supplying a DC voltage to an IC then you probably wouldn't hear anything.
                  Try shooting some Deoxit into the POT move it back and fourth about 10 times and see if that helps. A good place is usually where the leads go into the casing that's a clear shot to the wafer and wiper.
                  I haven't found a scratchy POT yet Deoxit couldn't fix.
                  • Logistics
                    • Apr 2007
                    • 721
                    Is there an air-conditioner or large refridgerator which turns on periodically in the house. Maybe it's causing a voltage drop due to a large draw, resulting in you seeing less volume.
                    Just an idea.
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      I use a pair of older Cambridge Soundworks PC speakers. I had a problem with low volume on the left channel. It went down but never came back up. On mine the RCA cable from the right speaker to the left was dying. I just stuck another RCA cable in it and its been fine ever since. Now I have another problem with them. The headphone output is stuck open. I guess it will cost about a big one dollar to fix it. I'm lazy. They may get fixed by 2011 or so.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • RetroComputingGrotto
                        Behringer MS16 Speakers - Low Volume on One Speaker
                        by RetroComputingGrotto
                        I've had a set of speakers come in with the fault of not powering on.
                        I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                        1 random loose nut and part of a BIC Biro pen.
                        After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                        05-20-2024, 07:29 AM
                        Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                        by momaka
                        More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                        02-15-2022, 12:43 AM
                      • Mcfeetroy
                        homemade speakers AN5277 How to adjust the volume?
                        by Mcfeetroy
                        Hello everyone. I soldered the speakers according to the circuit diagram on the AN5277 sound amplifier microcircuit. Everything works fine (I only added a ferrite ring to remove the sound transmission interference)
                        But I can't adjust the sound (there is no variable resistor or something similar for this in the circuit....Please tell me how I can adjust the sound? What needs to be added to the circuit?
                        10-27-2024, 10:19 AM
                      • karthur
                        Vizio D65x-G4 Volume changes on its own
                        by karthur
                        On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                        It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                        06-05-2025, 08:13 AM
                      • freethink
                        Kenwood KR-A70 Receiver Balance changes with volume controls?
                        by freethink
                        I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
                        11-23-2025, 07:53 PM
