homemade speakers AN5277 How to adjust the volume?
  • Mcfeetroy
    YaroGum
    • Nov 2021
    • 4
    • ATmega
    Hello everyone. I soldered the speakers according to the circuit diagram on the AN5277 sound amplifier microcircuit. Everything works fine (I only added a ferrite ring to remove the sound transmission interference)
    But I can't adjust the sound (there is no variable resistor or something similar for this in the circuit....Please tell me how I can adjust the sound? What needs to be added to the circuit?
    • 31260
    you ajust the input level.
    simple way is a pot,
    you put the wiper contact to the amplifier input,
    one end of the track goes to ground and the other end goes to the audio source.
    so as you turn the pot the amp input moves smoothly from ground to full input.
    10k is probably a good value to try - if it's not very linear you can try 4.7k or 47k.
    • redwire
      • 3912
      This circuit might help, pot 1 and pot2 are volume controls. Or you can use a dual potentiometer for volume control.
      Click image for larger version  Name:	AN5277 circuit.png Views:	0 Size:	11.0 KB ID:	3493680
      • Mcfeetroy
        YaroGum
        • Nov 2021
        • 4
        • ATmega
        Thanks everyone. I removed the 10kOhm resistor and put a 10kOhm variable resistor instead, it works great. But if someone is loud, then you can put it on 1kOhm so as not to terrorize the neighbors =)
        I love everyone, hug everyone =)​
          attaching AN5277 datasheet here. Missed it when fixing an issue with the first post
          • soeren
            A2442 - No sound over internal speakers and no video playback
            by soeren
            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
            All happened after the battery ran out of power overall several days when I was on vacation.
            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
            07-26-2024, 01:24 AM
          • RetroComputingGrotto
            Behringer MS16 Speakers - Low Volume on One Speaker
            by RetroComputingGrotto
            I've had a set of speakers come in with the fault of not powering on.
            I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
            1 random loose nut and part of a BIC Biro pen.
            After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
            05-20-2024, 07:29 AM
          • FuzzyOwl
            Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
            by FuzzyOwl
            Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
            Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
            Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
            I've followed the trouble shooting guide, audio check...
            12-05-2024, 11:54 AM
          • StrongTester
            Audio Jack on hp-ec1001np detects phones and external speakers but no sound
            by StrongTester
            Hello friends, I am having trouble with a hp-ec1001np that detects the headphones or speakers when connected to the jack, but no sound comes out. The normal laptop speakers work fine. Anyone has an idea what it might be? Did a full reinstall of windows, still nothing.
            05-30-2023, 10:29 AM
          • karthur
            Vizio D65x-G4 Volume changes on its own
            by karthur
            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
            06-05-2025, 08:13 AM
