Kenwood KR-A70 Receiver Balance changes with volume controls?
  • freethink
    • Sep 2015
    • 21
    I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
  • sretchko
    Sony Receiver STR-4800SD L/R Balance
    by sretchko
    Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
    The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
    When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
    I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
    Badcaps Electronics Repair Forum & Schematic Search
    04-17-2024, 06:02 AM
  • JRade
    Audio video receiver KENWood KR-V990D,no sound
    by JRade
    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
    I replaced the capacitor C303/0.047F, nothing changes.
    I'm asking for help, what should I do next?
    Thanks in advance!...
    08-05-2025, 10:23 PM
  • karthur
    Vizio D65x-G4 Volume changes on its own
    by karthur
    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
    06-05-2025, 08:13 AM
  • Mark R
    The Overseas Only Kenwood Model KR 790
    by Mark R
    I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
    The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
    09-23-2025, 08:27 PM
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
