Resistor unknown
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Resistor unknown
    Guys, im confused about this resistor. Its fully burned. I cant check the colors as well. When i checked service manual, this is what i see
    I check with parts vendor, even they dont know what value is this
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Resistor unknown
    post more of the schematic and the fried resistor, maybe someone can deduce the value from context and what it looks like now.
      +10
      Also pictures of the board.
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Guys, heres the schematic diagram for HTS-3366 Phillips. The resistor part number is
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          First guess would be 15Ω (brown, green, black, gold?), which does seem to correlate with the resistor having few spirals. Depending on the tuning of the SMPS, it may dissipate more than the ¼W that the resistor looks like it was rated for...
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Yes it has 2 spirals. 2 spirals usually is 10 ohms? I can see the resistor legs goes to pin 12V
            • Piotr07
              • Oct 2015
              • 17
              • Poland
              It is 15Ohm 1/2W
              • DjKrish
                • Oct 2012
                • 354
                • SG
                Originally posted by Piotr07
                It is 15Ohm 1/2W
                100% confirm bro? I dont wanna end up frying things there
                • CapLeaker
                  Leaking Member
                  • 8146
                  When I look at that schematic, the value of the resistor has to be low, but it isn't that critical, as the blown resistor is used as a fuse. I guess the zener diode may have shortened, causing the resistor to blow. 15 Ohm sounds about right to me.
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    Ok the thing is, the resistor burned, 2 caps shorted as per my checking using MM. All the voltage seems to be way higher than rated. The set is working but i dont wanna blow out the main board with excessive voltage by a faulty psu. I can see the display vfd is going at peak being over bright
                    So now ive replaced the caps and the IC, now need to figure out this resistor.
                      How much higher Voltage? It has 12V zener on one side of the resistor so it should be within 12V on the Zener side.
                      What do you get on the 12V line feeding the resistor?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        The voltage on the other side of the resistor can't be higher than 16V, and with good engineering practice wouldn't be much above 12V, even. I suspect that the zener was used for transient protection more than regulation.
                        Either way yes, a ¼W 15Ω maybe in the danger zone -- I only guessed this because of the physical appearance of the resistor with no ruler reference. A ½W resistor is probably safe for most uses, and a 1W resistor will give you enough leeway for other things to burn first before the resistor burns again, that is, if the zener or other downstream devices don't short out...
                          master hoarder
                          • May 2008
                          • 12170
                          • Bulgaria
                          +1
                          Unless the IC in that schematic you posted is bad (or something is shorting its output) or the 12V line feeding the resistor is high (runaway power supply?), that resistor should not burn out like it does.
                          Also, as eccerr0r suggested, you may want to go with a 1/2 Watt or 1 Watt resistor.
                          Regarding the value... does the resistor show any resistance on your multimeter? Sometimes, resistors can get pretty cooked buy still read in spec. That's because most (quality) resistor can usually handle twice to 4 times their full rated power before burning out.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            its a fuse .
                            • R_J
                              • 9535
                              It's a 15Ω 1/4 watt resistor, you can use 1/2 watt, Philips schematics have always been strange.
                              • DjKrish
                                • Oct 2012
                                • 354
                                • SG
                                Tell me about it , phillips service manual and their designs always been weird
                                • DjKrish
                                  • Oct 2012
                                  • 354
                                  • SG
                                  Originally posted by momaka
                                  +1
                                  I suspect, 2 caps were shot, so that burned out the resistor due to high voltage. The resistor has no reading at all
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    • Bulgaria
                                    Thanks for posting that info! Really interesting how they coded the specs on their schematics.
                                    Learned something new today
                                    Yes, quite possible, especially if those caps were filtering that 12V rail.
                                    I see it all the time with 2-transistor self-oscillating power supplies. O/P caps go bad and output goes wild.
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      Ok manage to replace the 12v diode and resistor, so far nothing burned. Next i will measure the voltages.
                                      I need to know, in the service manual it says KA7500C IC but on the board the IC is AZ7500BP-E1. I know its both 7500 but the letters seems diff. Any idea of they are the same?
                                      • DjKrish
                                        • Oct 2012
                                        • 354
                                        • SG
                                        Ok managed to measure all the voltages after replacing the IC, resistor, capacitors and 12v zener diode.
                                        12v - measures ranging 12.40v to 13v max
                                        5v - 5.19v and down
                                        -27v - -29v and below
                                        standby 5v stands at 4.89v
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
