Subwoofer Power Supply Problem
  • Logistics
    replied
    Re: Subwoofer Power Supply Problem
    I usually suggest Panasonic FM's from Digi-Key, but I think someone said the FC's, while not as low ESR nor high ripple, are made in a fashion that they withstand heat better than the FM's or last longer, something like that.
  • Toasty
    replied
    As these were General Purpose, low ESR won't hurt. You just don't have to go crazy and get super low.
    Go with 105°C caps. I'd also replace the other 4 small caps on that board.
    Find someway to ventilate the space to the outside, even if it is by convection.
  • atari
    replied
    I had searched the internet and could not find any information on the capacitors. When I called technical support at Onix (subwoofer manufacturer), they did not know either and did not have the service manual since the sub was discontinued.
    So, thanks jpdoe for finding this information on the REC capacitors for me. I see in the data sheet that ripple current for my capacitors is 925mA, however it does not state what the esr values are for the capacitors. Should I be looking for low esr capacitors ?
    The subwoofer is a sealed design (non ported). Also, the plate amp does not have any vents, it fits inside the sub's cabinet in a sealed hard plastic box, isolating it from the speaker. Now I am concerned about the heat build up and I would like to know if its safe to stay with a 85C capacitor ?
    These are the electronic retailers that I will be using to purchase the replacement caps
    http://ca.mouser.com/search/Default.aspx
    http://dkc1.digikey.com/ca/digihome.html
    http://www.e-sonic.com/acc/home.aspx
  • jpdoe
    replied
    Here's the datasheet, for someone more experienced than me on finding replacements.
  • atari
    started a topic Subwoofer Power Supply Problem
    I purchased the subwoofer 'Rocket ULW-10' around 2005 and recently was experiencing a humming noise coming from the sub. So I researched the problem on the internet and it was suggested on various forums that this could be a capacitor issue.
    After checking the audio source and for grounding issues, I then decided to open up the subwoofer plate amplifier. What I discovered was that 2 of the capacitors on the power supply board were blown.
    The 2 capacitors had the following specifications:
    'PEC' or 'REC' , SR , 1000uF , 25V , 85C
    Now I am assuming from looking at the power supply that it is a linear design and not switch mode design.
    What would be a good replacement for these capacitors ?
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • madan1
    555 based power supply getting too hot
    by madan1
    Good day.
    I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
    The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
    After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
    When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
    06-23-2025, 04:38 PM
