Novation SuperNova 2 Rack - Freezes up.
  • jwillifixit
    • Apr 2017
    • 113
    • usa
    Hi there fans of the Supernova 2... I have recently come into ownership of a rack model and it's not working properly. I was hoping that if I describe the issue someone here might be able to point me in a direction.
    Okay here goes... It powers on and all the lights flash once then the display shows "Supernova" than it adds "voices 24" and on the next line "O/S version 2.0" as it is changing to that the Part buttons 1-8 and the edit button light up than the display changes to show "Seq 30303 Dist" and on the second line "Prog A049" and a few of the lights are lit. Seems normal enough.
    Okay I found out how to play the factory demo and was playing that but didn't mess with any knobs or buttons. There are 3 demo's and I did move from one to another a few times... I let it sit playing one of them and it played for quite some time like that just fine.
    Well I turned up the master volume and it just sort of locked up. Display was still lit but no button or knob did anything... volume up/down didn't change anything. I couldn't change any menu or setting.
    I used some contact cleaner and cleaned the pot's a bit. After that it seemed to be working correctly (let me add that I am not a musician and have no input source for this - I've only output from the headphone out to powered speakers). I moved around through several menus and discovered that it would make sounds if you hit the part buttons... way cool sounds I might add!!! Okay this is great I'm thinking. Well not so much because now it's back to doing the same thing. I can start it and move a few knobs and then it locks up and won't do anything. If I'm in the demo it freezes on the last sound and just starts looping it (same if I'm hitting a part button). Display is illuminated and all it's just non-responsive. Okay - thoughts? I'd love to get this working and try to put a Casio LK-220 I have into a computer and output Midi to the synth and PLAY!!!
    • 31061
    Re: Novation SuperNova 2 Rack - Freezes up.
    open it and UPLOAD some foto's of the power supply section.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      I'd second that ^^^
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • jwillifixit
        • Apr 2017
        • 113
        • usa
        Sorry for the delay... here's the pic's. Power supply board and the processing board. I've ordered what from research I believe is a replacement psb and it'll be here monday so we'll see what that does.
          • 31061
          very nice, perfect soldering - very clean on top.
          caps could be aged, but nothing visible.
          • jwillifixit
            • Apr 2017
            • 113
            • usa
            Well the replacement PS arrived today and that was not the problem... issue remains. Must be on the processing board. I think I'm going to send this in to Novation for repair evaluation/quote. I love the sounds I've been able to make this thing make!!!
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Photos of that, perhaps? Bad caps could be lurking in there too.
              Odds are good they farmed out the power supply (or got it from some OEM), so just because that has jap-caps, doesn't mean they didn't cheap out on the ones on the main board...
              • jwillifixit
                • Apr 2017
                • 113
                • usa
                Here's the main board. I didn't pull the front panel board but here's a stock pic of what this unit looks like from the front. That's a LOT of rotary pot's. Anyway I've opted to send this to a service center that works directly with the OEM of the unit. They just received it the other day so we'll see. Again... this is a really sweet '80's synth and my total cost of ownership will simply be the shipping and repair cost so...
                • CapLeaker
                  Leaking Member
                  • 8190
                  On the bottom left of the board, looks like there are 2 voltage regulators?
                  • jwillifixit
                    • Apr 2017
                    • 113
                    • usa
                    Thought I'd update and close out this thread...
                    So I sent the unit into an OEM recommended repair facility (American Music and Sound
                    A Division of Jam Industries USA in Southhaven, MS). Now there's a few threads on Gearslutz about how crap Novation products are and how bad the service is at AMS. I can't speak to the Novation product quality issue as I have no real experience there. I can tell you that this synth that I picked from the dump and is basically 20 years old is working perfectly with only minor repair required so...
                    Here's my experience with AMS: I got an RMA and sent them the unit. I followed up to confirm they got it and then followed-up a week later to see how it was progressing. I was told by the service leader that it was on the bench and a tech would be looking at it that day. I didn't hear anything for a few days so followed up again - normally was getting someone on the phone right away but that day it was a long time and finally just left VM and followed-up with an e-mail. From that day forward I was in e-mail contact with the actual tech working on my machine.
                    We had several exchanges about the issue and what he was doing... long and short of it was it needed the firmware (ROM) flashed because it had become corrupt and it needed one rotary pot replaced. Total = 2 hours labor (inspect, diagnose, repair) and $2.50 for the part. As this had none of the knob heads/covers on it he also asked if I had knobs for it stating that he had just enough spares for it and would include them for free if I needed them. I told him I did not and would greatly appreciate it!
                    Total bill:
                    Outbound shipping $36
                    Repair $132
                    Return shipping $20
                    33 free knobs -$196.35
                    So I got this jem serviced and back better than I shipped it and I'm $8.35 to the good!!!
                    The tech also included a printed copy of the owners manual in the box.
                    I am beyond satisfied with the service I received from AMS!
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      That's pretty great!
                      I've had a similarly positive experience with Focusrite's own tech-support in the UK. A year or two back i had bought a faulty Scarlett 18i8 (USB socket was destroyed), which also had a few screws and a couple plastic bits missing. After a couple emails back & forth, the guy sent me the missing bits for free!
                      Pretty much the same story with a Scarlett 18i20 earlier this year - after some troubleshooting, turned out the firmware had gotten garbled up. They ended up sending me a preprogrammed replacement one, once again, for free Along with one or two plastic button tops (one had snapped off).
                      • jons
                        • Feb 2014
                        • 59
                        • Latvia
                        Great stories from both of you!
                          Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                          by sam_sam_sam
                          Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                          I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                          09-13-2024, 06:47 AM
                        • grosseader
                          MSI B450 Gaming Plus Max - freezes randomly
                          by grosseader
                          Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
                          What is the issue:
                          PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
                          Hardware:
                          MSI B450 Gaming Plus Max , MSI A320m A-pro
                          BIOS : 7B86vHG - latest
                          CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
                          GPU: Vega 7 in 3200g and MSI 1060 6GB
                          RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
                          01-30-2023, 03:24 PM
                        • hinisa
                          Xiaomi router freezes at boot after re-capping
                          by hinisa
                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                          07-08-2023, 05:58 AM
                        • kuba2102
                          Medion Erazer beast x25 freezes and resets only at low CPU usage
                          by kuba2102
                          Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
                          Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
                          01-06-2025, 09:14 PM
                        • mferna14
                          ASUS G513QE-SB91-CB freezes all of a sudden
                          by mferna14
                          Dear Friends., I am working on an ASUS Model: G513QE-SB91-CB, Serial # M8NRKD041417338, Motherboard: G513-6050A3249301-MB-A03(A3). The problem is that while using the laptop, just freezes all of a sudden., & sometimes while booting the ring stops to spin. I replaced with known good Memory & the a New SSD, installed Fresh Win 11 on this same laptop. Did not freeze during installation. But when re-booted, Win 11 boot ring stopped. I turned off from the power button. Again turned on & it booted well to Windows. Upon Windows update, it froze again. Even the BIOS has been updated &...
                          11-28-2024, 08:21 PM
