can not having speakers hooked up blow an amp
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    My dad said not having speakers hooked up to an amp that is on can blow the amp. I think he was thinking about tube amps.
    With a modern 100w/ch amp, whats the chance of this happening.
    I mean, a surround 5.1 with the two front and center hooked up, but no surround speakers eventually damage the amp?
    It has three dual channel amplifier IC's (because one channel has a subwoofer, which will also be hooked up)
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: can not having speakers hooked up blow an amp
    Actually , no , because most of the modern Amps detect the presence of the speakers and act according to it .
    Your dad non the less is speaking good about an old era where no digital processors were used in old Amps . If there wasn't speakers , yes , Audio IC's would be blown out ..
    • jazzie366
      • May 2016
      • 304
      Don't be so quick to make this statement, I learned the hard way!
      You can still run amps with only one channel loaded. They will see the speakers as being there, but they can't see if ALL channels are loaded! You can still blow the amp this way! Cheap car stereos work this way, such as the Dual XDM16BT, a 17$ @ walmart bluetooth radio. It's amazingly well made, but it has the fatal flaw of turning the amp on when only one speaker is connected, and faults with an acceptable resistance will also turn it on. It did however save it's own ass when I accidentally nicked a wire and it went to chassis ground. Easy fix. HOWEVER I did blow one of these out by being a dumbass! I have a 600$ 2003 Mitsubishi Eclipse. I got it because it was a last minute, "fuckit" decision. Well, it came with a radio from the 1990's, and two blown stock speakers. The rear speakers were replaced with Lightning Audio (good!), the stocks were left in the front (bad!) and they were frozen from corrosion... Needless to say, the reciever suffered some damage. The left side works fine, right side is dead due to a short. So don't be so quick to judge, shit isn't perfect.
      However, on things like my 1969 Rotel RX-550, if you turn it on and play music with no speakers attached, it will blow sky high. Newer amps, maybe not, maybe so. Friend has a cheapo Pioneer unit that has had only two of the 4 channels playing, but sound going to all 4 (it's stereo). It still works fine even when you throw speakers on the rear channel. So in reality it's a hit or miss. Just be careful and don't do that.
      Popcorn.
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        That's why we say something is of high quality and something isn't .. Something is cheap and something is really worth buying ..
        Notice that i always use (most ) and not (all) .. And i do agree with you
        • jazzie366
          • May 2016
          • 304
          Well I mean I was comparing a 17$ unit with a pioneer unit which for one of the same feature level costs 60$ minimum . ITE just don't take the risk, especially if it's sensitive equipment or high end.
          Popcorn.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            I know what you mean . I once bought a Pioneer headphones for 350 $ , yes , some 25 years ago . and it's still working like nothing else ..
            We cannot say the same about today's quality of course .. Everything is degrading , but when i say most , i always have the Chinese crap in my mind .
            When repairing Any kinds of Audios systems , Usually , the first step i do , is using headphones , and the second is to measure the internal resistance of the speaker .
            The third step is reading instructions , manuals and every references .
              master hoarder
              • May 2008
              • 12175
              Even *most* not-so-modern amps will be okay. I can't speak for tube amps, as I don't have any experience with those, but just about every transistor amplifier from the 60's and up - even the most crude designs - typically won't have an issue with disconnected speakers. Shorted or lower-than-suggested impedance speakers - now that's a different story.
              The way transistor amplifiers are designed - at least class A, B, and AB amps - the output transistors cannot output a higher voltage than their +/- supplies. So whether you have speakers connected or not should not matter at all. If an amp blows up because its speakers are disconnected, it was probably faulty to begin with or it's a shit amp that deserved to blow up anyways, lol.
              Another thing to think about: if the amp has A/B/A+B speaker switches, those usually disconnect one set of speakers before connecting the other set. This alone can present a scenario where the amp has a "no load" condition from any speakers. So clearly not having speakers connected can't be an issue if the amp has those switches. For a modern-day 5.1 Amp, you probably have a switch to select whether you want Stereo or Surround. But it does pretty much the same thing as the A/B/A+B selector switches (except it is all controlled by logic these days, and the speaker switching is done through relays rather than an actual switch making the speaker connections).
                Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                by momaka
                More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                02-15-2022, 12:43 AM
              • nomoresonys
                Connect pc speakers to tv without 3.5 jack
                by nomoresonys
                Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
                09-19-2025, 05:17 AM
              • Widget
                Logitech R20 speakers - Replacing one of the speakers.
                by Widget
                Hi guys,
                I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                Printed on the back of the Logitech speaker is;
                LOGITECH...
                05-29-2024, 07:07 AM
              • Stephen
                A2991 Logic Board issue, 20volts 0 amps help!
                by Stephen
                Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                09-10-2025, 03:16 PM
              • Stephen
                A2991 logic board issue, 20volts 0 amps help!
                by Stephen
                09-10-2025, 03:15 PM
