pioneer vsx 2021 no sound
  • srt1
    • Aug 2013
    • 177
    • india
    i got a pioneer vsx 2021 , it is secondhand item, everything is working except sound, ther is no sound in all channel. but i can get sound in if it put in pure direct mode. only front left and right channel. is it bad cap problem?
  • mmartell
    • Oct 2013
    • 3189
    Re: pioneer vsx 2021 no sound
    Likely a problem on the hdmi board.
    • srt1
      • Aug 2013
      • 177
      • india
      I think so.. any one can help me to fix it?
      • mmartell
        • Oct 2013
        • 3189
        HDMI boards are pretty complex. Check regulators and ic's for voltage.
        • srt1
          • Aug 2013
          • 177
          • india
          Yes you are right i check every signals. i found that Main clock signal is missing for DAC ic chip and DSPchip. clock signal lost due to one regulator ic Bad its show only 1.3 volt as per schematic it should be 3.3Volt then i by passed 3.3volt from another regulator ic now i am getting sound
          • mmartell
            • Oct 2013
            • 3189
            Great ! How did you check for missing clock signal, scope ?
            • srt1
              • Aug 2013
              • 177
              • india
              I dont have scope. only have digital multi meter but in that i can measure i2s audio signal and 44.1khs sampling frequency. i measured these signals on DAC ic chip. then i by passed main clock out from DIR ic chip to DAC ic chip then i got sound. so i check in schematic i found that there is buffer ic in between . this ic chip do not producing output clock signal due to regulator failure.
              • Nufus
                • Jun 2018
                • 4
                • Poland
                Hello.
                I have the same pioneer vsx 2021 and damage.
                Do you remember which elements you replace?
                I can not find service manual vsx2021. You use service manual similar type pioneer?
                • srt1
                  • Aug 2013
                  • 177
                  • india
                  Originally posted by Nufus
                  Hello.
                  what is the damage? no sound? yes i have service manual.i will upload here
                  • Nufus
                    • Jun 2018
                    • 4
                    • Poland
                    No sound in all channel and tuner searching station but can not find AM FM stations . I bought a damaged secondhand.
                    When I will be service manual I will try to fix it.
                    • srt1
                      • Aug 2013
                      • 177
                      • india
                      http://smanuals.ru/manuals/home-thea...x-53-1326.html
                      • Nufus
                        • Jun 2018
                        • 4
                        • Poland
                        Would you by send manual another server?
                        • Piotr07
                          • Oct 2015
                          • 17
                          • Poland
                          Here you are ! Of course, registration is necessary http://**************/load/audio/vsx_lx55/5-1-0-52442
                          Limits do not allow to place such a large file in the forum.
                          • Nufus
                            • Jun 2018
                            • 4
                            • Poland
                            Thank you for links service manual.
                            I ve checked voltage supply and regulators are ok.
                            Main receiver shows version is displayed 1-204087***008
                            If I update firmware, only 20% stops and show error.
                            *** - ? chip DSP
                            I have to replace chip D810K013BZKB400 ?
                            • dobrykamil
                              • Jun 2013
                              • 62
                              I've got VSX-LX55 with the same issue-no sound. Looking for service manual. Anyone can help me out here?
                              Cheers.
                              • Clunche
                                • Mar 2020
                                • 12
                                • France
                                Hello, I own a second-hand VSX LX-55 which is similar to the VSX-2021 that you fixed. The issue is probably the same, I have no sound at all even in direct mode via the CD inputs. I have tried to locate the service manual but could not despite my many attempts. Would someone be kind enough to share a download link for this manual so that I can start tracking down signals on the HDMI board? Thanks a lot. Chris.
                                • madan1
                                  • Nov 2016
                                  • 670
                                  • Bulgaria
                                  You can download the service manual from here https://www.hifiengine.com/manual_li...vsx-lx55.shtml ( requires free registration )
                                  • Clunche
                                    • Mar 2020
                                    • 12
                                    • France
                                    Very kind of you to provide this link, thank you. I downloaded the two manuals but unfortunately they are incomplete and very short (8 pages only each): no schematic diagrams of the boards found in the LX-55. Would you have another suggestion where to look? I have tried many different places unsuccessfully
                                    • madan1
                                      • Nov 2016
                                      • 670
                                      • Bulgaria
                                      try here elektrotanya.com
                                      • Clunche
                                        • Mar 2020
                                        • 12
                                        • France
                                        Nope, no luck either, they don't have it, I am familiar with this good site. I've checked some Russian sites as well and I did not find it.
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • Jaxxon0121
                                          Pioneer PDP 436 SXE Strange Sound
                                          by Jaxxon0121
                                          Hi all, im new here and a complete novice with electronic repair so please bear with me. The problem i have is with my Pioneer PDP 436 SXE TV 43' plasma tv. Its recently started making a strange clicking/popping/electrical sound that is very loud and annoying. The tv works fine other than that. The sound doesnt happen straight away. After around 10 minuets of use, usually when the screen turns black on a tv program or if i exit a youtube video and the scrren goes black for a split second, that is when the sound begins and then doesnt stop at all until the tv is unplugged. The sound is coming from...
                                          04-30-2021, 08:47 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                          LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook Specification for Upgrade or Repair
                                          This specification for the LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY boardview and GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:10 AM
