pioneer vsx 2021 no sound
  • Decim8
    • Apr 2022
    • 7
    Re: pioneer vsx 2021 no sound
    The unit I just fixed had 26k hours on it at time of failure, if the new one goes half that I'll be happy.
    Can the 830s be used in place of an 810? Reason I ask is I accidentally ordered an 830 for this project and wondered if it would work. Still waiting for it to show up. The 810 came right away so I used it.
    • andyb1712
      • Oct 2018
      • 41
      #42
      As far as I'm aware, the D830 is the same chip as the D810 but it has network and USB functions built in. I don't however know if it can be used in place of the D810 without checking a schematic for a receiver that uses each device to be sure the connections are the same.
      The problem with these Chinese supplied chips is you don't know how many hours they've logged before being salvaged and reballed. The extra heat cycles involved in removing, reballing and refitting can't help longevity either.
      The Onkyo TX-NR636 is the model to look for (or it's HDMI board) in a faulty condition because it has both a D830 D and D810 D on it. If you can get the amp to power up, you can at least check the hours usage before deciding whether to use it for parts or repair it and sell on.
      The power amp on the 636 seems quite fragile compared to similar older models so it can be picked up fairly cheap when it goes up in smoke. Only trouble is, it's still fairly current with Dolby Atmos and HDMI 2.0 etc so can be sold for more than an old Pioneer like the VSX-2021 or VSX-LX55
      • bugler13
        • Jan 2021
        I have the same problem, full controls but no audio and no clock signals on VSX-1021-K. Reflowed the DSP with no avail. Unable to find the firmware for the VSX-1021-K. So I am tempted to try Andy's VSX-2021 firmware. Very little to loose, any thoughts?
        • andyb1712
          • Oct 2018
          • 41
          #44
          I've not worked on the VSX-1021 but if it uses the same DSP chip it may be possible to patch your firmware with part of the LX55 one. I found that the area that gets erased is 0h to 10,000h. If this is blank, cut and paste that area from my file into yours. It should get it running and then you can do a full update from USB.
          If the DSP is the BGA variant it should be warm to touch after a few minutes running. If it's cold then it has probably failed. Reflowing it sometimes works but reballing or replacing is better.
          The other thing to check is the firmware version in the system menu. If it shows *** in part of it, the firmware is corrupt or the DSP has failed... or both.
          • coutts
            • May 2019
            • New Zealand
            #45
            Hi Andy,
            You don't happen to have a DSP FW dump from a working VSX-922 do you? I'm fixing my DSP IC (UE22 error), and also will need to reflash my eprom.
            Thanks heaps!
            Chris
            • nodols
              • Jan 2023
              • 24
              Here's a Dropbox link to the file I modified and used to update my receiver.
              You can use this over and over because the receiver thinks it's getting a new update but it just reloads the same version.
              https://www.dropbox.com/s/7efo8tqpzi...pdate.zip?dl=0
              Hi Andy, not sure if you are still here, the link no longer works. Would appreciate if you could provide a new upload link?
              I have a VSX-52 with the no sound issue, I flashed the EEPROM with the bin you have provided in post #29, and it fixed the no sound issue.
              Only thing is that the FM doesn't work or there is no sound and the "tuned" display stays lit all the time. Even if it's not tuned to a any FM frequency station.
              If I force it to tune to a known FM station in my locality no sound comes out from it.
              I'm just wondering if this is because of the EEPROM flash or just a faulty FM module.
              Also, I have fully updated through USB update to the latest version. It won't update through net. It just keeps on saying accessing then nothing happens., but USB update works fine.
              I tried updating again, now it says " Update not needed" or something.
              I was wondering if I could get a copy of the EEPROM that you provided to trick the receiver into updating again and again. Just wanted to try it.
              Thank you.
              • R_J
                • Jun 2012
                • 9563
                Pioneer has taken down there links to the firmware, I suspect the online update server has also been shut down.
                The firmware you installed is for Europe so that is likely why the FM is not working.
                I found this as the original link that is not working
                pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/VSX-53_52_1121/Ver1_204_087_119_093/AVR_1_204087119093.zip
                But found what should be the file.
                I can upload it if you want to try it.
                • nodols
                  • Jan 2023
                  • 24
                  Try it at your own risk.
                  Hi R_J, thank you for this. I tried updating the receiver using this file. It just keeps saying "NO NEED UPDATE".
                  This is the reason I wanted I asked a copy of @AndyB1712 's file and what he says in his post #36 link below. Wherein I think he tweaked the firmware and this fools the receiver into thinking this is a new update.
                  https://www.badcaps.net/forum/showpo...0&postcount=36
                  He provided a dropbox link, but that link now is dead. So I'm hoping he uploads it again.
                  • R_J
                    • Jun 2012
                    • 9563
                    This is why links are n.f.g. they disappear. Have you tried changing the file name to a higher number, like avr_12_0243 ?
                    The other option might be to change revision and release numbers in the file itself
                    • nodols
                      • Jan 2023
                      • 24
                      Doing it now.
                      • nodols
                        • Jan 2023
                        • 24
                        I tried renaming the file. Still says "NO NEED UPDATE", I'm thinking this is internal to the programming.
                        Not sure how to change the revision itself. Might need a hex editor? only thing is that's where my know-how ends.
                        • R_J
                          • Jun 2012
                          • 9563
                          I changed it from 12_0242 to 12_0243, using hex editor, see it it works.
                          Does it display the current firmware? maybe that could be a clue what to change.
                          I did not want to leave the files up incase it did not work. I can upload the edited file if needed.
                          • nodols
                            • Jan 2023
                            • 24
                            Where have you uploaded it? Can't seem to find it.
                            • R_J
                              • Jun 2012
                              • 9563
                              I took it down again, If the revision number I changed doesn't work there is no point it leaving it up.
                              • nodols
                                • Jan 2023
                                • 24
                                Oh ok. I guess it's up to Andyb1712, I hope he logs in again.
                                • R_J
                                  • Jun 2012
                                  • 9563
                                  If you want to try the file where I changed the version number let me know.
                                  • nodols
                                    • Jan 2023
                                    • 24
                                    Sure. I'll try it.
                                    • jockyw2001
                                      • Jul 2020
                                      • 9
                                      • Hong Kong
                                      #58
                                      ## Attached - DSP firmware dump from Pioneer VSX-LX55 ##
                                      Tested and working in both VSX-LX55 and VSX-2021.
                                      Circuit location is: IC9004, device is: MX25L1606E.
                                      Version is 119 from Pioneer firmware AVR_1_204087119093
                                      I loaded this into my VSX-2021 IC9004 although the rest of the receiver was still running an older firmware version. It then started up and ran fine. I was able to perform a full update via USB to the rest of latest version detailed above.
                                      Thx so much for your work Andy! After flashing your file my VSX-2021 with a 'B' DSP and with the *** instead of DSP flash part# is producing sound again. Luckily, the MX eeprom could be flashed on-board with AsProgrammer. After switching on I checked the firmware number and was initially sad to see it was still showing ***, but after a few seconds it changed to 119. After toggling the source selector I immediately got UE22. After rebooting it a second time, there was no UE22 and there was sound via the VIDEO input. I still have to try HDMI inputs, but even if they cause UE22 I'm still happy I can use it with analog stereo sources. I should add that first off I heated the DSP IC9002 for about 40 seconds with a heat gun set to 270 degrees celcius ~1.5cm above the chip.
                                      I still have a problem though... I can't find any firmware upgrades. It is currently on version 1-191-086-119-063.
                                      Can anyone share the latest version with me?
                                      • humaxnet
                                        • Apr 2023
                                        • Italy
                                        #59
                                        Please, anyone can share or post last firmware for Pioneer VSX-LX55?
                                        Regards
                                        • Bertramsri
                                          • May 2021
                                          • Italy
                                          #60
                                          Pioneer HM 82 K No audio
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Jaxxon0121
                                            Pioneer PDP 436 SXE Strange Sound
                                            by Jaxxon0121
                                            Hi all, im new here and a complete novice with electronic repair so please bear with me. The problem i have is with my Pioneer PDP 436 SXE TV 43' plasma tv. Its recently started making a strange clicking/popping/electrical sound that is very loud and annoying. The tv works fine other than that. The sound doesnt happen straight away. After around 10 minuets of use, usually when the screen turns black on a tv program or if i exit a youtube video and the scrren goes black for a split second, that is when the sound begins and then doesnt stop at all until the tv is unplugged. The sound is coming from...
                                            04-30-2021, 08:47 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                            LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook Specification for Upgrade or Repair
                                            This specification for the LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY boardview and GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:10 AM
