Pioneer PDP 436 SXE Strange Sound
  • Jaxxon0121
    • Apr 2021
    Hi all, im new here and a complete novice with electronic repair so please bear with me. The problem i have is with my Pioneer PDP 436 SXE TV 43' plasma tv. Its recently started making a strange clicking/popping/electrical sound that is very loud and annoying. The tv works fine other than that. The sound doesnt happen straight away. After around 10 minuets of use, usually when the screen turns black on a tv program or if i exit a youtube video and the scrren goes black for a split second, that is when the sound begins and then doesnt stop at all until the tv is unplugged. The sound is coming from a silver box at the back where you plug the power cable into the tv, which i presume is the AC Filter. I took the original part out and replaced it with a new one but the noise is happening with the new part as well so i presume that it is not that causing the noise. im going to share a youtube link with a video of the sound and the back removed from the tv so you guys can have a look and listen for yourselfs. Thanks for the help in advance, if i can get this fixed i will be really happy as ive recently starting to get into repairing electronics and im really enjoying it!
    Many thanks
    Jack
    Links:
    Youtube: https://youtu.be/eQD4g_m3PR4
    Ac filter (Where the noise is coming from):
    https://richelectronics.co.uk/produc...-plasma-om0400
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Pioneer PDP 436 SXE Strange Sound
    I'd give the set a good dusting and then check all the solder joints of all the coils and any other component that is mounted on a heatsink. Also check all transformer joints.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      +1 also check any caps in the audio area, I had one with the amp mounted on a heatsink. I think there was a few 100uf caps that were out on ESR-chemicon brand if I remember wired whooshing/popping sound through the speakers.
      The AC filter shouldn't be making that sound, check all power supply solder joints as DB said normally indicates a lose connection that becomes reactive to temperature change.
      • Jaxxon0121
        • Apr 2021
        Thanks for the reply's guys. I've cleaned up the entire set and took a few boards out and cleaned them and check for any bad solder joints but they all looked fine. I've got a bigger problem now though, when I power it on, the noise remains but now the tv won't come on and it shuts off after a few seconds and the standby light flash in successions of 2, then when I power it on again the blue power light blinks 8 times in a row. I've checked all connections and they seem to be perfectly fine and in there place. Not sure what I've done
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Check all the boards you removed are back in place securely and that you have not missed a connector out.
          Post some photo's so people can see the interconnections between boards.
          • televizora
            HP 8470p - distorted sound and noise when playing audio
            by televizora
            Hello.
            I have an issue with HP 8470p - rather strange one.
            I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
            Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
            Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
            12-31-2021, 10:25 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • LEECH666
            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
            by LEECH666
            Good day ladies and gentleman!
            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
            01-19-2024, 05:46 PM
          • GraphicMan
            Pioneer A-205 faint noise/hiss issue
            by GraphicMan
            as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
            what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
            out of curiosity what does that mean?
            thanks
            05-19-2024, 11:45 AM
          • Francesc V.
            Tele-master AS-20 amplifier. No output sound, just noise
            by Francesc V.
            Hi:
            I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
            I've checked fuses and all are ok.
            I've continued with capacitors:
            • The main black one should have 4700uF, but it has lost half of its capacity during these years.
            • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
            The 4 transitors are perfect. Desoldered and tested individually.
            There are also components which I don't know exactly what they are....
            02-16-2023, 07:55 AM
