Philips FR-740 working but no audio output
  • seve91
    • Oct 2013
    • 75
    • Italy
    i got this Philips FR-740...it powers on, i can see the front display, but no audio output at all.
    No burning components on the motherboard. Any suggestions?
    Here there is the service manual
    thanks
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Re: Philips FR-740 working but no audio output
    Does it power on normally, or is it some error like protect? If it powers up with no error, maybe something is stuck in the head phones jack?
    • R_J
      • Jun 2012
      • 9607
      plug in some headphones to see if there is sound from the headphone jack
      • seve91
        • Oct 2013
        • 75
        • Italy
        No, it powers on normally, no errors.
        No items or other stuff inside the headphones jack.
        Inserting IN and OUT the headphones is correctly detected.
        For example with headphones connected, i cannot enable the surround mode, because it says (take out headphones first).
        If i disconnect headphones, then i can enable surround mode.
        Headphones are working good, very good and clean sound.
        • R_J
          • Jun 2012
          • 9607
          Looks like if it has audio to the headphones, there should be audio getting to the input of the stk ic's. Did you try all the outputs? meaning the sorround speakers as well.
          I guess check and make sure you have + & - 40 volts to the ic's, then I would check the solder connections on the ic's sometimes they break
          Since its not in protect I would think there is 0 volts at the + of all the speaker terminals, maybe check and make sure.
          • seve91
            • Oct 2013
            • 75
            • Italy
            Yes i tried all the output speaker (2 front, 2 rear, 1 center).
            +40V and -40V is present in both STK, solder connection looks perfect.
            These voltages are printed in the philips schematic:
            STK496-070 (i have STK496-090 in the pcb):
            9 = 39,5V
            3 = 40V
            8 = -39.5V
            12 = -33.6V
            1,2 = -40V
            4,5,6,7,10,11,13,14 = 0V
            STK496-270
            11 = 39,5V
            14 = -33,5V
            10 = -39,5V
            3,4,19 = -40V
            7,8,9,12,13,15,16,17,18,20 = 0V
            Measured those values, all verified. But -33.5V and +-39.5V is a little bit higher, cause voltages are 40.2V.
            • seve91
              • Oct 2013
              • 75
              • Italy
              advices?
              • seve91
                • Oct 2013
                • 75
                • Italy
                please any help?
                  • 31254
                  any schematics around?
                  philips used to sell the service manuals so someone must have scanned one!
                  • seve91
                    • Oct 2013
                    • 75
                    • Italy
                    sure, here is the link:
                    but can't figure it out what is the problem. Voltages seems to be all present. Maybe the final amplifier are broken
                      • 31254
                      page 16,
                      make sure all 6 volume settings are centered.
                      page74 shows the audio leaving the input selector into the amp circuits through an electrolytic.(2541,2542)
                      i would scope or tap off of that to see if the audio is making it through the switching section first.
                      this is a complex bastard, but atleast the schem's are readable!
                      • seve91
                        • Oct 2013
                        • 75
                        • Italy
                        Originally posted by stj
                        page 16,
                        page 16, all volumes centered.
                        page 74: i have signal on both 2541 and 2542. Checked the output of the opamp (pin 1 and 7), signal is good.
                        page 75: i have signal on inputs of TDA7437, front and surround ok
                        page 76: i have signal on 2534 and 2535, no signal on 2536-2537.
                        page 79: i have signal on 2310-2316, and also 2334 if i enable surround. no signal on 2905-2913 even with surround on.
                        • R_J
                          • Jun 2012
                          • 9607
                          On page 79, whats the voltage on Q7310 collector? Also check if the amp on/off circuit is working.
                          • seve91
                            • Oct 2013
                            • 75
                            • Italy
                            ok, page 79:
                            A of 6305: 0V
                            K of 6305: 3.2V
                            C of 7309: 0.04V
                            C of 7304: -41.5V
                            C of 7310: -41.5V
                            • seve91
                              • Oct 2013
                              • 75
                              • Italy
                              any help?
                              • R_J
                                • Jun 2012
                                • 9607
                                It looks like the comand from the front panel is not turning on the amp, I think A of 6305 should be around 4.5 volts not 0
                                On page 34 the Amp lr on comand comes from ic7412, I see there are also a couple led's off that ic, dvd & Surr, is it posible to comand those led's to change from the front panel? to make sure the ic is receiving comands.
                                • seve91
                                  • Oct 2013
                                  • 75
                                  • Italy
                                  Yes, both leds are working DVD is on when input 6CH/DVD is selected. SURR is on when you push surround button (surround is not available in 6CH/DVD mode)
                                  • R_J
                                    • Jun 2012
                                    • 9607
                                    looks like ic 7412 is working, Do those other lines change like the Amp lr on (pin 6 of 7412) or mute (pin 7) Those lines could be checked on plug 1410 also
                                    • seve91
                                      • Oct 2013
                                      • 75
                                      • Italy
                                      Pin 6 always 0, pin 7 alway 4.9V
                                      • R_J
                                        • Jun 2012
                                        • 9607
                                        On plug 1410 pin 11 amp prot (page 34) do you have 4.4 volts? Its hard to follow where things connect in this old type pdf (can't search)
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • mecha1166
                                          Copper corrosion? Yamaha HS8S Audio 1 output only
                                          by mecha1166
                                          OAUD Yamaha HS8S Audio one output only.
                                          I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                                          08-04-2023, 02:55 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • dicky96
                                          Denon AVR-X500 No audio output
                                          by dicky96
                                          Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
                                          I only have 2x 8ohm speakers attached to Left and Right front.
                                          If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
                                          I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
                                          02-22-2022, 08:36 AM
                                        • k24a1
                                          JVC I'Art AV-27F703 Left speaker audio not working
                                          by k24a1
                                          Hello Badcaps.net!
                                          I have an old-school CRT TV that's a JVC I'Art 27F703 from july of 2002 that I use for my older game systems. It has been working great until I noticed that the left speaker is not working. I have also tried adjusting balance and trying external speakers, and that even had the same issue though the equipment itself passed the sound test! I actually took a closer look inside and some of the capacitors on the audio circuitry portion of the mainboard were starting to leak underneath! They were samsung capacitors and uh, I don't see those ever being touted as reputable.......
                                          06-21-2023, 09:38 PM
