JVC I'Art AV-27F703 Left speaker audio not working
  • k24a1
    Computer Witch
    • May 2023
    • 10
    Hello Badcaps.net!
    I have an old-school CRT TV that's a JVC I'Art 27F703 from july of 2002 that I use for my older game systems. It has been working great until I noticed that the left speaker is not working. I have also tried adjusting balance and trying external speakers, and that even had the same issue though the equipment itself passed the sound test! I actually took a closer look inside and some of the capacitors on the audio circuitry portion of the mainboard were starting to leak underneath! They were samsung capacitors and uh, I don't see those ever being touted as reputable.... LMAO.
    Is anyone skilled with this specific model of TV and can anyone give me an insight on what's going on? I plan to do a full recap to fix the distortion issues that aren't related to any geometry settings and also to make it operate more reliably, but I'm also asking here because I am curious if something else should be replaced. Yes, I did have all the stereo cables connected and I even checked the user settings. The service menu doesn't have a mention of it either and both speakers look perfectly fine. It appears to be an issue in the audio circuitry itself or in the A/V board.
    I have attached the service manual of this TV so you all can look through it. I don't have a lot of time to figure it out and I'd like to get this TV working again as soon as possible.
    Thanks in advance!
    Non-binary, she/they. :^))
    Technology enthusiast who likes working on computers, video game systems, and other electronics.
  • k24a1
    Computer Witch
    • May 2023
    • 10
    Re: JVC I'Art AV-27F703 Left speaker audio not working
    I forgot to reply to this (I had a painful kidney stone that left me sleepless for several nights) but I've determined the culprit. These I'arts have crappy blue Samsung capacitors that start to leak after a while, and replacing those fixed the audio issue. Mine was used quite a lot before I got it so I knew something was going on with the capacitors. The other capacitors seemed fine though, only the larger blue samsungs had the issue of leaking on the bottom. Luckily, nothing was severely damaged and now that the replacement was done I have stereo sound again!
    • nomoresonys
      • 12307
      • U.S.
      It was overdue for a recap, electrolytics are not really expected to last more than 10 years, although some can and have lasted for 50 or more years.
      • k24a1
        Computer Witch
        • May 2023
        • 10
        Several months later and the TV is still working with good audio! Yeah, I'd personally do a full recap but I'll have to put a lot of money into that, and for now it works perfectly fine.
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
        • hemant_2222
          Yamaha 2064 No sound but Test audio working
          by hemant_2222
          Hello Guys,
          Greetings!
          Hope you all are doing well.
          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
          PCM1681DBQR - IC263 and it worked fine.
          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
          11-01-2025, 11:20 PM
        • obelix24
          Macbook Air a1932 only right speaker working
          by obelix24
          I just got one macbook air a1932 that is fullu working (no signs of liquid damage but there is strange issue that only right speaker is working (that one that is connected directly to audio board)
          the other one is not working at all.
          i've tried to replace left speaker 3x and still no sound, i've also replaced audio board but still the same.
          Do you know what can cause this issue ?
          10-30-2024, 01:31 AM
