Philips FR-740 working but no audio output
  • R_J
    • Jun 2012
    • 9608
    Re: Philips FR-740 working but no audio output
    It should'nt be hard to find a transitor to use for now, almost any pnp rated higher than 60v should work.
    So with that transistor out of circuit do you have audio out of the speakers?
    did the voltage on 7310 (C) drop a bit lower from before?
    With that transistor out of circuit, any comand from the front panel should have no effect on turning the amp ic's on or off, so if there still is no audio (and you have it at the stk inputs) then that voltage on the CCC line must still be too high
    • seve91
      • Oct 2013
      • 75
      • Italy
      #42
      replaced 7309, 7304, 7310, 7902, 7909. same voltages remain.
      Could be a bad capacitor somewhere? Why the voltage is too high?
      • seve91
        • Oct 2013
        • 75
        • Italy
        #43
        No still no audio voltage on CCC too high, don't know why. Without transistor, C of 7310 is -37.7V.
        Tried replacing cap 2350 without success
        • R_J
          • Jun 2012
          • 9608
          I don't know why either, what ever it is effects both amp ic's correct? as both are turned off.
          What are the voltages on transistor 7261 & 7260 ?
          • seve91
            • Oct 2013
            • 75
            • Italy
            #45
            sorry friend, i've just reassembled it. I give up.
            Too much time wasted, and can't find a solution still.
            Thanks to you for all your kindness and patience, your tips were useful to improve my troubleshooting skills.
            • R_J
              • Jun 2012
              • 9608
              Maybe put it away for a while and come back to it later, sometimes a break is needed and when you look at it another time the answer may come easier. It is likely something simple that is being over looked.
              I also looked at the service manual for the FR975, it is very similar and a lot clearer to read, although the voltages are a bit different (slightly higher for more power) they are very close
              • seve91
                • Oct 2013
                • 75
                • Italy
                #47
                i don't know...maybe you're right.
                For sure I don't have so much experience... I go on with attempts.
                The amplifier is not mine, the owner is a friend.
                If she wants to bin it, then i will take it back.
                • seve91
                  • Oct 2013
                  • 75
                  • Italy
                  #48
                  Hi everyone, due to Lockdown here in Italy, I decided to disassembly the Philips FR740 again to find out the issue. Hope to fix it this time.
                  • seve91
                    • Oct 2013
                    • 75
                    • Italy
                    #49
                    IC7412 got 2 faulty output. Replaced, now i have 4.9V on AMP LR LINE, but still no sound.
                    On the C of 7309 i have -21V instead of -34.5V, and I have -40V on C of 7304, and I have almost -40V on pin 14 CCC instead of -33.5V (C of 7310).
                    HST & DC Protection Circuit seems to be good.
                    Very low voltages on 7909 and 7902.
                    All those transistor have already been replaced.
                    Any advice?
                    • seve91
                      • Oct 2013
                      • 75
                      • Italy
                      #50
                      Fixed! -VPl was missing, found an high resistance on 3901 (should be 47ohm). Replaced and now seems to be working good.
                      Usually when a resistor is broken, i can see a black spot or something. This one was perfect like new, and i can measure an high resistance instead of the usual open circuit.
                      Thank you everyone very much for your help!
                      • R_J
                        • Jun 2012
                        • 9608
                        Good to here it's working, If that's a fusable type resistor, it might not show that it is bad.
                        • FrancescoV
                          Onkyo HT-R390 no sound output, video output ok
                          by FrancescoV
                          Good morning everyone,
                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                          The firmware reported is the following:
                          M:1.00/11107BLP
                          D:?.??/????????
                          O:1.00/11107AL
                          The DSP firmware given the question marks seems corrupt.
                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                          05-11-2025, 02:59 AM
                        • mecha1166
                          Copper corrosion? Yamaha HS8S Audio 1 output only
                          by mecha1166
                          OAUD Yamaha HS8S Audio one output only.
                          I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                          08-04-2023, 02:55 PM
                        • flibidy
                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                          by flibidy
                          I have here a Magnum IA.100 which belongs to my parents.
                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                          What Ive done........
                          01-01-2025, 01:26 PM
                        • dicky96
                          Denon AVR-X500 No audio output
                          by dicky96
                          Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
                          I only have 2x 8ohm speakers attached to Left and Right front.
                          If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
                          I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
                          02-22-2022, 08:36 AM
                        • k24a1
                          JVC I'Art AV-27F703 Left speaker audio not working
                          by k24a1
                          Hello Badcaps.net!
                          I have an old-school CRT TV that's a JVC I'Art 27F703 from july of 2002 that I use for my older game systems. It has been working great until I noticed that the left speaker is not working. I have also tried adjusting balance and trying external speakers, and that even had the same issue though the equipment itself passed the sound test! I actually took a closer look inside and some of the capacitors on the audio circuitry portion of the mainboard were starting to leak underneath! They were samsung capacitors and uh, I don't see those ever being touted as reputable.......
                          06-21-2023, 09:38 PM
