Teac CD PD-H400 Tray Opening Intermitantly
  • Wishiknewmore
    • Mar 2013
    • 13
    • England
    Hello
    I have just "inherited" a Teac CD player because the drawer will not open, I have just opened it up and place a CD in and the machine seems to work OK except for the drawer
    On pressing the open/close button it can work repeatedly then 10 minutes later it wont!
    When it works, it works well, not stiff or sticking
    Unplugging and re-plugging seems to fix the problem ---for a while!
    I am very much an newbie on this stuff so may have missed something very obvious
    Give me a clue!
    Many thanks in anticipation
    Philip
    • 31219
    Re: Teac CD PD-H400 Tray Opening Intermitantly
    when it wont work, can you hear a small motor running?
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      Most have a rubber belt running the tray in and out and it stretches. Like STJ mentioned you'll hear the little motor run for a few seconds.
      sigpicThe Sky Is Falling
      • Wishiknewmore
        • Mar 2013
        • 13
        • England
        I was going to say no,but I have just been playing with it far the last 10 mins and it worked repeatedly for about 25 times then stopped and when trying there is a very short run of a motor
        I don't immediately see any belts ...lots of geared wheels and toothed racks
        It is quiet a sizeable and well built looking mechanism, but I have yet to take it out of its chassis/case
        I find it strange that it works immediately after a reconnecting the power as if it has rebooted or something
        Do you think it needs to come out?
        Philip
          • 31219
          the belt is under the tray at the front - you have to remove the tray to see it.
          to do that, you need to press one or two clips at the back of the tray or on the frame to let it pull right out.
          • Wishiknewmore
            • Mar 2013
            • 13
            • England
            I can see it now
            It is still intact but I assume that it is worn/perished/stretched
            Any suggestions how I determine the correct size?
            Many thanks
            Philip
              • 31219
              is it tight?'
              a foto would help
              • Wishiknewmore
                • Mar 2013
                • 13
                • England
                See attached best photos I can do
                I would not describe as tight as there is not a straight line --it seems to bow a little
                suggestions?
                Thank you
                  • 31219
                  for now, take it off and clean it and the rollers with ipa,
                  then try to work out the diameter so you can find another.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Sounds a bit odd but i saw a video the other day on how to measure belts the person took the old belt of then used dental floss he wraped it around the two pulleys like the old belt went tied a knot when it was tight he cut the floss and measured it then ordered the correct lengh belt i will try to find the video and link it.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      That's one way I've used. If I had a good belt left, I'd just squeeze it together and measure it. Then double it and pick the next smaller standard diameter. Remember it's stretched out a bit. That looks like a square belt too.
                      You need to know where to get one too. Those chinese belts only last about 6 months. I put them in a cassette deck that is probably the hardest one you'll ever see to change belts in. I was not happy when it quit working because of those brand new belts.
                        • 31219
                        i just take them out of pc drives that i bin.
                        • Wishiknewmore
                          • Mar 2013
                          • 13
                          • England
                          Thanks everybody, I will clean it,measure and replace and let you know the outcome
                          Philip
                          • ChaosLegionnaire
                            optical drive tray loading problem
                            by ChaosLegionnaire
                            i started using a couple of my optical drives again to perform some testing and backup but to my disappointment, they have tray loading problems. both drives wont eject the tray and when i load the tray back, it auto ejects the tray again. it seems that the laser sled assembly in the drives wont drop down fully to the correct position to release the tray and the laser sled assembly wont extend back up to the proper position to lock and load the tray so it auto ejects the tray again.
                            i tried lubricating the gears in the tray loading mechanism and the tray sled rails but it didnt...
                            02-26-2019, 02:07 PM
                          • bogosort
                            Sony DVD player stuck tray (DVP-SR310P)
                            by bogosort
                            I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                            Anyone knows why?
                            Thank you....
                            05-11-2024, 04:29 PM
                          • avneeshshrotria
                            Mac Pro 5,1 2010 CPU Tray Damage
                            by avneeshshrotria
                            Hey guys ,
                            Need assistance with a Mac Pro 2010 5,1 single cpu , cpu tray .
                            Ive bought the computer used , it’s really been through a hard time.
                            Someone has managed to pull components off the bottom side of the cpu tray!!!
                            I need assistance in identifying the components and the values of
                            1. CG410(missing)
                            2. Q2400(TWN. Marking on it) , Q2450(TWN. Marking on it) (this marking does not correspond to any specific IC as far as I can tell , need help to identify!l )
                            3. Q2120 (missing) ,
                            4. R2444(missing)
                            Im attaching a couple...
                            04-11-2024, 02:20 AM
                          • CoinCoin88
                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                            by CoinCoin88
                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                            09-15-2025, 03:36 AM
                          • s_specialist
                            Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                            by s_specialist
                            Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                            07-07-2025, 11:47 AM
