optical drive tray loading problem
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    i started using a couple of my optical drives again to perform some testing and backup but to my disappointment, they have tray loading problems. both drives wont eject the tray and when i load the tray back, it auto ejects the tray again. it seems that the laser sled assembly in the drives wont drop down fully to the correct position to release the tray and the laser sled assembly wont extend back up to the proper position to lock and load the tray so it auto ejects the tray again.
    i tried lubricating the gears in the tray loading mechanism and the tray sled rails but it didnt change the problem. in fact, it got worse because the rubber belt for the tray loading motor got slippery due to all the oil lol! any idea how to fix the tray loading issue with the drives? thanks.
    • 31214
    Re: optical drive tray loading problem
    clean the belt pulleys with IPA and get new belts - belt-stretch and deforming is a common problem.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Back in the VCR service days, there used to be belt assortment kits your could get....it doesn't seem to be that easy for optical drives....I have several that do this and are in need of belts....all of them use different size belts.
      One nice thing about old gear-driven Plextors!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • 31214
        i'v seen kits,
        either at banggood or aliexpress.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          well, i was wondering if a rubber band of the appropriate size and strechiness would work well as an intermediate ghetto fix stop gap to get the tray working and loading right again. i need to use the drives immediately for testing and cant wait weeks for shipping from overseas regardless if its new belts or a new optical drive...
            • 31214
            weeeelllllll - you could splice one together with superglue!
            • R_J
              • Jun 2012
              • 9593
              Elastic/rubber bands do not work, try cleaning the old belt. If it won't open that easy, open the drive manually. most cd drives use a small pulley, this causes a sharp bend in the belt and after sitting a long time the belt forms to the pulley and the pulley just spins and won't turn the belt
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Just like how I thought that engines should have a timing gear and cam timing gear...
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  master hoarder
                  • May 2008
                  • 12175
                  They do, but it's a crapshoot. I've done it on a few drives, and most didn't last more than a few years, if even that. This is mainly due to the fact that regular rubber bands will degrade a lot quicker than a proper belt - even if you wore surgical gloves and never got any oil on the rubber bands!
                  So all in all, I agree - it doesn't work well long term. And even short-term, the results could be iffy.
                  +1
                  I find that this works a lot better than getting cheap "replacement" belts online - most of which are simply regular rubber bands and not proper belts.
                  Oh I have a few drives like that. I don't remember if they were Lite-On or LGs... I think LG drives. Some models just develop this problem after a number of years, and it's not the belts - it is wear on the first big pulley/gear after the motor catching on the screw on top. No easy way to fix it. So the way I work those drives:
                  - On eject, I press eject button and insert a paper clip into the hole to help the drive tray eject.
                  - On load, I press eject/load button and "help" the tray go back in by pushing it and giving it a quick jab/accelerating towards the end.
                  Hell yeah!
                  My indestructible Teac CD-540E CD-ROMs are the same way. One even has broken guides (came from a dumpster-picked PC), but it still ejects the tray fine - quite roughly, though.
                  • dmill89
                    • Dec 2011
                    • 2534
                    Some do: Most heavy truck engines, Dodge Cummins diesels, most old International Harvester engines back when they made pickups/SUVs, Ford 4.9L I6s, Ford flat-head V8s, old Willys Jeep engines (1950s and earlier), etc.
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3266
                      • Singapore
                      many thanks to stj and R_J for the belt and pulley cleaning tip. cleaned a couple of my drives and the tray now ejects and loads fine now after testing the tray ejecting and loading several times after cleaning.
                      so it seems that rubber is a biodegradable material so changing the rubber belts prolly wont work and fix it long term. the rubber will just degrade again. so its a design problem with the drives using a material that degrades over time aka planned obsolescence again! when cleaning the belt and pulleys with 70% ipa (medical grade), the tissue i was using to clean it got black stains on it. guess that is the decomposed rubber residue?
                      regarding the rubber belt deformation problem, yes. when i pulled the rubber belts from the drive to clean, they were indeed egg shaped as well instead of being round shaped. i tried bending the rubber belt the other way to "iron" out the kink but it didnt work so well. its still slightly egg shaped... yea i know its a pretty nub thing to do but i just had to try it out to see if it works lol!
                      • eccerr0r
                        It's 2025: do you know where your 5¼" floppy drives are?
                        by eccerr0r
                        Oh wow.
                        As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                        Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                        Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                        Weird. Seems the PC drive is having trouble clamping...
                        07-07-2025, 12:49 AM
                      • AJ847.63e
                        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                        by AJ847.63e
                        Hi Folks,
                        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                        05-06-2025, 10:37 PM
                      • eccerr0r
                        failing hard drives after sitting for years...
                        by eccerr0r
                        With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                        Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                        Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                        03-02-2023, 10:33 AM
                      • bogosort
                        Sony DVD player stuck tray (DVP-SR310P)
                        by bogosort
                        I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                        Anyone knows why?
                        Thank you....
                        05-11-2024, 04:29 PM
                      • abajor
                        Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                        by abajor
                        I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                        I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                        The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                        Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                        04-23-2024, 11:43 PM
