Yamaha RX-V665 After 3 sec. shuts down
  • linksys1127
    • Sep 2016
    • 121
    I am new to this so please bear with me. My in-laws have a RX-V665 av receiver that will not stay powered on. When it initially quit they heard a loud pop through the speakers and then no sound. I got a copy of the service manual and put it in the self diagnostic mode and it powers on for 3 seconds with "DC PRT: 000L" on the display before it powers off. It does this 3 times then will not allow anymore power ons until I unplug and replug back in. My troubleshooting abilities in electronics are limited and any guidance would be greatly appreciated. Just don't know where to begin.
  • CapLeaker
    Leaking Member
    • 8000
    Re: Yamaha RX-V665 After 3 sec. shuts down
    I'd say you have a shorted output transistor and the amp is in DC protect mode. As soon as the protection circuit senses DC on one of the output channels, it will protect itself and your speakers. So check the output transistors. Upload your service manual some pictures, so we have something to look at.
    • linksys1127
      • Sep 2016
      • 121
      Here is a compressed version of the service manual. Too large to send in original format. Thank you for your help!
      Kevin
      • linksys1127
        • Sep 2016
        • 121
        I'm fully capable using a multimeter just not so capable troubleshooting electronics but trying to learn. I'll take some photos when I get home from work today. Just need some guidance on where these transistors are located and testing them. Im guessing they would be shorted to ground if bad? Thank you
        • CapLeaker
          Leaking Member
          • 8000
          There is a huge heatsink inside. So either there are "bricks" or individual transistors mounted to that heatsink. That's where we need to look at. I can't look at that zip file on my tablet, but I'll get it when I am on my PC again.
          • linksys1127
            • Sep 2016
            • 121
            Not sure but here's what I found out. I powered the receiver on and checked each large ceramic resistor while the power was on. Took several tries due to it cycling off after a few seconds. I have three large bricks mounted to the large heat sink and seven large ceramic resistors near the large heatsinks.i got 50v DC on R1068 and 1v DC on R1067. Those 2 get their input from IC100 p/n STK433-330-E, one of the large brick transistors. The other resistors are 0 volts. Does that mean the brick transistor is the faulty component? Thank you
            • linksys1127
              • Sep 2016
              • 121
              • linksys1127
                • Sep 2016
                • 121
                Here's a pic of the three large IC's and the white ceramic resistors I checked for voltage during power-up. The one on the right is IC100. The one in question. Thank you again for your help on this!
                • linksys1127
                  • Sep 2016
                  • 121
                  Well, it flipped my picture. It's the IC on the top right.
                  • CapLeaker
                    Leaking Member
                    • 8000
                    Look at the PDF page 116. There are the three output bricks. R1068 is on the Right channel output. So if you have 50V on that (or pin 4 on the brick), the IC100 is bad.
                    You need to find a replacement brick.
                    IC100:
                    pin 4/5 right speaker output
                    pin 6/7 center speaker output
                    pin 18/19 left speaker output
                    • linksys1127
                      • Sep 2016
                      • 121
                      Thank you so much for your help! I'll order a new IC brick and update this when I get it installed.
                      • linksys1127
                        • Sep 2016
                        • 121
                        This is what the inside of the IC looks like. You can see several burned spots. Thanks to Capleaker's help in troubleshooting I replaced this IC and my in-laws are back in full surround sound. Thank you sir!
                        Kevin
                        • Flaviocb22
                          • Dec 2017
                          • 4
                          • Brazil
                          do you think this works on a rx v379?
                          • lowpost99@gmail.com
                            Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                            by lowpost99@gmail.com
                            I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                            09-03-2024, 02:57 PM
                          • platinumsteel
                            hp labtop 15-db008 Powers On then Shuts Off
                            by platinumsteel
                            Hi guys have an issue with a friends labtop that has no signs of liquid damage.They said it just stopped turning on.When i press the power button it turns on normally like 35-500millamp draw and it posts and i have picture. But like after 4 seconds after it posts an image it shuts off completely.If i press power button again same thing happens. Did all basic troubleshooting with the motherboard like fresh thermal paste with it completely out the chasis with battery disconnected. Thermal camera shows these two mosfets heating up more than anything else when i press the power button.I have provided...
                            10-28-2023, 10:51 AM
                          • survivalbloke
                            Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                            by survivalbloke
                            I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                            Any ideas?
                            01-08-2024, 12:12 PM
                          • sanalelevenstar
                            Yamaha RX-V485 Wn9711 Update
                            by sanalelevenstar
                            Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                            I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                            I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                            12-04-2024, 04:32 AM
                          • huzo
                            HP Omen shuts down when loading OS
                            by huzo
                            The model is 15ec-1061nm
                            Board number is DAG3EDMB8D0​
                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                            10-29-2024, 12:05 AM
