Yamaha RX-V485 Wn9711 Update
  • sanalelevenstar
    • Jul 2024
    • 12
    • INDIA
    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or J755 for RX-A2A) to reset the network module. Since the RX-V485 appears to use the same network module, I suspect a similar fix might apply.
    However, I couldn't find any documentation or information about the soldering points for the RX-V485. I've searched the service manual but had no luck identifying them.
    Has anyone here encountered this issue with the RX-V485? If so, could you point me to the soldering points or share any advice on how to resolve this?
    I'd appreciate any guidance, images, or steps that could help. Thanks in advance for your support!
    Best regards,
    Sanal Kumar
  • dobrykamil
    • Jun 2013
    • 69
    Shorting J260, puts MPU's "MODE" leg (pin 145 of TMP4G9F15FG) to the GDN. If your avr has the same MPU, then try to manually short that pin to GND, but before you do that, check if that pin has 3.3V when avr is on.
    • sanalelevenstar
      • Jul 2024
      • 12
      • INDIA
      on my Rx-485 there is no Shorting point Like J260 but i find service manual "mode leg" J207 so i tried short that pin nothing happening
      • Plurxtc1
        Yamaha RX-A2A WN9711 Update
        by Plurxtc1
        I have a RX-A2A that doesn't do anything besides stuck with WN9711 Update. Any ideas I can get pass this screen?...
        11-18-2022, 12:18 PM
      • keeper5511
        Asus strix z490-g gaming wifi bricked after bios update
        by keeper5511
        I have a motherboard Asus strix Z490- g Gaming wifi and a 10th gen CPU. I have update BIOS to 2701 version but then I realized that I needed to update the ME firmware first. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site. I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. Now the motherboard have "No power issue" and it seems dead!!! My attempts to reflash it were unsuccessful. Searching online, I found several people...
        03-25-2026, 02:01 AM
      • longmt1990
        Please help my Panasonic Cf-QV1 bios update stuck
        by longmt1990
        I have a Panasonic CF-QV1. After receiving and installing a firmware/BIOS update from the manufacturer, the machine restarted and now constantly displays the error message: 'ROM Image is not loaded / ROM Image update denied'.
        I have already tried clearing the CMOS (disconnecting the CMOS battery) and accessing the BIOS via Windows recovery to restore default settings, but without success.
        Every time the laptop boots up, the screen still throws the 'ROM Image is not loaded / ROM Image update denied' prompt. I have to press ESC and manually select the SSD to boot into Windows.
        10-02-2026, 02:18 AM
      • akwky
        by akwky
        Hi!
        04-14-2025, 01:56 PM
      • Kuat
        Troubleshooting Audio Equipment Yamaha CVP-505
        by Kuat
        Subject: Yamaha CVP-505 IC204 Sub1 Boot ROM dump needed (MX29LV160DBTI-70G)
        Hello, I'm repairing a Yamaha CVP-505 Clavinova. The Sub1 Boot ROM chip IC204 (MX29LV160DBTI-70G, Yamaha part YA452A00) is corrupted. Diagnostic test 002 shows "No Card". The original chip data was partially erased before I could read it. I need a dump from a working CVP-505 IC204 chip (Sub1 Boot version 1.03 according to service manual). Can anyone with a working CVP-505 read this chip and share the dump? The chip is TSOP48, 2MB NOR flash....
        09-24-2026, 01:13 AM
