Harman/Kardon Onyx Bluetooth Speaker - No Power
  • caphair
    • Nov 2011
    • 1249
    #141
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    I wonder if the Bluetooth module needs to see 4.5v at the charge pin regardless if the speaker has its own charge circuit? Maybe that's how it controls the power leds?
    • fzabkar
      • Mar 2009
      • 772
      ISTM that we need to determine how the BM153/BM150 module connects to the circuit.
      According to Sunitec's BM153 datasheet ...
      Code:
      PIN NAME   TYPE          FUNCTION
      13 VDD   Power         +3.3V Supply
      14 VDD_USB Power         Positive supply for UART/USB ports, Connect to VDD
      32 VDD_BAT Battery terminal +ve  Lithium ion/polymer battery positive terminal.
                        Battery charger output and input to switch-mode regulator
      34 VDD_CHG Charger input     Lithium ion/polymer battery charger input
      35 LED1   Open drain output   LED Driver
      36 LED0   Open drain output   LED Driver
      The module's VDD supply comes from the 3.3V SMPS regulator, as apparently do the VDD_BAT and VDD_USB pins. You should verify the continuity between these pins with your multimeter, after disconnecting the battery.
      We now need to determine where the VDD_CHG input comes from. The BM153 datasheet is telling us that it connects to the BQ29040 input pin, which is the output of the 4.67V regulator. However, I suspect that VDD_CHG would be connected to the /CHG pin of the BQ29040. The charging IC drives this pin low whenever it is charging the battery. Once again, you could test for continuity between these pins. Also measure the voltage on this pin when the charger is disconnected and when the battery is present and not present.
      Obviously the Bluetooth module drives the LED, not the BQ29040.
      BAT54C is a mystery. I would test for continuity between the 4.67V regulator and pin 1, and between the battery +ve terminal and pin 2 (with the battery disconnected). I don't understand how you came to measure a higher voltage (4.74V) on pin 3.
      • caphair
        • Nov 2011
        • 1249
        #143
        Continuity between VDD/USB/BAT checks
        I get no continuity between VDD_CHG, input or /CHG pins on charger ic it doesn't look like it has a trace/connected to anything
        Also 0v on that pin with charger disconnected, battery in or out
        So VDD_CHG is supposed to see a voltage even if there's an external charge circuit?
        Continuity checks between 4.67v regulator and pin 1
        No continuity between battery positive terminal and pin 2 (of charge ic if that's what you meant)
        BAT54C puzzled me too, I even just now measured 5v at the common cathode! So not sure what's going on there, should be a .6v voltage drop from charger input right?
        • fzabkar
          • Mar 2009
          • 772
          In retrospect, the VDD_CHG pin must be high, not low, so it cannot be connected to /CHG, as you have verified. Sorry about that.
          Anyway, I don't have any more ideas. If I were doing this job, I would trace the circuit around the battery, BM150 module, and the BQ29040. Without this information, I'd only be guessing. Perhaps someone else has some better insight.
          • caphair
            • Nov 2011
            • 1249
            #145
            Yeah idk either I might just throw in the towel. At least it powers on and works. If you or anyone comes up with any other ideas, please feel free to post. Thanks for all your help!
            • maxximum
              • Dec 2015
              • Magyarország
              #146
              Had the same problem, no power on,
              D300 has burning signs, replaced D300 but still no power on. If touched R304 by wet hand and push power buton, it powers on, soo checked R304, it should be about 45 kOhm, but was only 17 kOhm. It connects to C306 too, resoldered C306 that had a teporary short or solder problem and now everything is OK.
              BR: maxXimum
              • caphair
                • Nov 2011
                • 1249
                #147
                BR: maxXimum
                Nice! Does your power indicator continuously blink even if fully charged? Never figured that issue out
                • maxximum
                  • Dec 2015
                  • Magyarország
                  #148
                  Hello, if fully charged, it turns on solid, no blinking.
                  BR: maxXimum
                    • Jul 2011
                    • 6039
                    I have Bluetooth device and had a problem were the battery charged up fine the first time I ran the device until it shut off and recharge it over night but the charge LED light would not turn off
                    So I replace the battery with a much bigger battery and the charge LED light went off it could be there is something wrong with the battery or the protection board on the battery
                    I have seen where the protection board do not ether have power out or can not handle current load or where they shut the charging off early
                    I have seen batteries that would not reach the 4.2 battery voltage they should
                    This means that battery has issues and will have service live issues
                    I hope this helps
                    • LFCD2
                      • Aug 2016
                      • 3
                      • Brazil
                      #150
                      Hello. I have a question for the experts: A portable external battery that provides exactly 19.59 volts (3.5A) is possible to use in the power input ? This VOLTAGE ( TENSION ) can damage the internal components? The amperage (3.5A) I know it's possible , my question is specifically the voltage ! This external battery can also provide 16.67 volts (and 12.55v). Would be better ? (I have a good multimeter...) Sorry , I can not write well in English ...
                      Thank you.
                      • LFCD2
                        • Aug 2016
                        • 3
                        • Brazil
                        #151
                        I have another portable battery option for power input : 18.55 volts. It is better than 19.59 volts ? Thank you.
                        • dj01fad
                          • Sep 2014
                          • 92
                          • romania
                          #152
                          hello there.
                          I have the same device, but another problem.
                          When I hold the power button for at least 3 seconds (sometimes over 5), it cames alive for one second, and then powers off.
                          I did the voltage check, the pin 3 reset is at 3.25V and when I press the power button it drops.
                          Please help, any ideeas?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4955
                            • New Zealand
                            #153
                            Are all your power voltage rails OK?
                            -David VanHorn
                            • dj01fad
                              • Sep 2014
                              • 92
                              • romania
                              #154
                              Everything is OK with the voltage rails. I have power on the IC amps, I have power on the BT module; the unit starts then shuts down.
                              I've checked the IC apms, and no shorts on them; also, in that second when it's on, I can hear some fsssssss on both channels.
                              What else can I check?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4955
                                • New Zealand
                                #155
                                Either should work in place of the 19v external charger, but to be on the safe side I would use the 18.55v supply. The audio amps are rated for 20v maximum, I believe.
                                Do NOT use it in place of the internal battery, which is rated for 3.7v!
                                -David VanHorn
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4955
                                  • New Zealand
                                  #156
                                  Is the sound you hear the normal sound it would make without input, or is it abnormal?
                                  -David VanHorn
                                  • dj01fad
                                    • Sep 2014
                                    • 92
                                    • romania
                                    #157
                                    I have no ideea if it's normal (maybe it's normal, it has no distorsions). I have it from a friend, and I received it broken.
                                    I can make an audio record and post it if it would help, but no sooner than monday because I'm out of town now.
                                    Thanks!
                                    • LFCD2
                                      • Aug 2016
                                      • 3
                                      • Brazil
                                      #158
                                      thank you. I changed my portable battery 19,5v (using rectifier diodes ) to 18,9v , considering the load. So is working well , it is 5 hours of autonomy with the high volume !
                                      • vdshop
                                        • Oct 2016
                                        • hcm
                                        #159
                                        I ask prices Harman Kardon Onyx Studio 3 speakers how many? I bought it purchased?
                                        http://viendongshop.vn/harman-kardon-onyx-studio-3.html
                                        chu ky so, chu ky so ca2, chu ky so fpt
                                        • dinosaur84
                                          • Dec 2016
                                          • Vietnam
                                          #160
                                          Harman Kardon Onyx Studio 1 has been die (can't power on)
                                          Could you help me to resolve it?
                                          • funky2x
                                            Harman kardon onyx studio 7 Smd code
                                            by funky2x
                                            Cant find what smd code Y0DVA.
                                            sitting in Harman kardon onyx studio 7. Appreciate any help.
                                            05-29-2025, 03:44 PM
                                          • dorfman
                                            Dell Harman Kardon Dead Left Speaker
                                            by dorfman
                                            Working on an early 2000s dell / harman kardon computer speakers.
                                            Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
                                            I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted...
                                            09-03-2022, 05:39 AM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • magneh
                                            Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
                                            by magneh
                                            Hi
                                            Long story short, Harman Kardon Aura Studio 2 speaker, no power.
                                            Disassembled, found burned IC, maybe the 5V regulator? not sure
                                            No schematics
                                            IC marking: 225S2 (see pic)
                                            Board ref: 40-KS320U-PSK2G
                                            Thanks for any help!...
                                            09-16-2021, 08:41 AM
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
