Panasonic radio plays only one side
  • Behemot
    • 4845
    • CZ
    Got this radio where only one side plays. The amplifier section seems pretty simple, there is basically LA4705N responsible for everything. Anybody has some experience with that? Is it the main suspect?
    • 31007
    Re: Panasonic radio plays only one side
    link the left & right input pins to get your answer.
    • Behemot
      • 4845
      • CZ
        • 31007
        if it's a stereo chip and you link the left & right input pins, you can see if you get sound from both speakers.
        otherwise, feed some sound through it and scope the inputs to the amp section.
          • 31007
          link pins 2 & 7
            Using capacitor so you will not cause Voltage offset.
            • Behemot
              • 4845
              • CZ
              Some ceramic?
              Originally posted by stj
              link pins 2 & 7
              But why inputs? Why not outputs?
                • 31007
                it's a btl amp, designed for bridging - if you link the outputs you blow the chip because they are out of phase.
                it wouldnt prove anything anyway.
                by shorting the inputs to the amp, you are finding if the channel is missing before, or inside/after the amp chip.
                  master hoarder
                  • May 2008
                  • 12170
                  Or you can link the pins on the input coupling capacitors, not on the side that goes to the chip (i.e. pins 2 and 7) but their other side. That way you won't need to any caps to test the circuit and it works just the same .
                    If the input side of the caps are connected to the pots then it will be fine but if they are connected to the active devices such as the Collector of the Transistors (or the Emitter as in Emitter follower, or output of the OP-AMPs) then that can be the problem since you will tie the Collector of the Left and right Transistors together. Better find out how they are being used first before doing any direct connection.
                    • popeye
                      • May 2011
                      • 155
                      Hi I take it this is a stereo amp then you dont even need a schematic because all you need is in front of you check between the componant measurements
                      from one side of the out put to the other working one if your fault is not there check you are getting the correct inputs if in puts are ok then problem is with the ic if not you know what you should be getting from the working side so compare.
                      • Behemot
                        • 4845
                        • CZ
                        It does the same for all settings (radio, CD player) that's why I think input is OK as it goes from different sources with same result.
                        The headphone output usually goes through amplifier or not? If not I can try some and in such case I guess I can call input OK too?
                          master hoarder
                          • May 2008
                          • 12170
                          Most of the time, they are connected to an electronic switch that toggles which source (i.e. radio, tape, or CD) go to the amp. After that, there is usually a resistor, the amp input coupling caps, and the amp itself. At least that's what I have seen in most "modern" (90s +) units.
                          But I agree. It is better to check what is connected to what before blindly jumpering stuff.
                          In many cases it does.
                          So yes, check with headphones. If you do get sound from both channels with headphones, it could be the headphone jack switching contacts are messed up or just dirty.
                          The way the output on most boomboxes and "mini" stereo systems is done is you have the outputs from the power amp going to the headphone jack. The headphone jack has switching contacts. If you plug in headphones, the output goes to the headphones and mutes the speakers. If you unplug the headphones, the contacts in the headphone jack switch to route the output to the speakers. Inexpensive stereo PC speakers also do it this way.
                            • 31007
                            look at the schematic in the datasheet.
                              You have the scope so that will be so simple to trace where the signal gets lost at, GOOD AC Volt meter will do as well.
                                • 31007
                                is it fixed yet?
                                i could fix this while waiting for the kettle to boil.
                                • Behemot
                                  • 4845
                                  • CZ
                                  You got teleport device?
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    is it fixed yet?
                                    Not unless it is a "modified" kettle by PhotonicInduction
                                    https://www.youtube.com/watch?v=dDLw1Rx_cAI
                                      • 31007
                                      seriously, probe pins 2 & 7 for audio.
                                      if it's on both, check between the ic and speakers - and check speaker coils.
                                      no issues? then the chip is bad.
                                      missing audio on one of the pins first checked? then trace it back.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        I am just moving from shared shop to my own room so I already have 2/3 of my stuff moved and 1/3 is messed everywhere around. Don't even have room for the radio on my table, it is quite huge and I don't want to mess with my O-scope ATM. Thanks for the input so far, I'll try when I am moved completelly. I am exhausted every day last week…
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
