Akai Reel To Reel Capacitors
  • Maxxarcade
    • Jul 2006
    • 973
    I am working on an Akai GX-260D reel to reel that I need some caps for.
    The service manual calls the caps "MP capacitors". They appear to be bipolar electrolytics from 250-350v ac.
    The problem is, a couple of them are large multi-section caps that I can't find anywhere. The one I need most is 1uf/3uf 350vac, with radial leads.
    Can I replace these caps with mylar or poly ones?
    Also looking for the cover that goes over the heads.
  • Logistics
    • Apr 2007
    • 721
    Re: Akai Reel To Reel Capacitors
    I actually started looking through the Digi-Key catalog, but then thought, "Multi-section bipolar?!?!?!" >_< Don't think I've seen that before.
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      Multi-section lytics? Have those been made since the 50s or 60s? I think looking into individual polypropylene film caps might be a promising route. Just be careful to select AC-rated types or a sufficiently high DC voltage (assuming these aren't safety caps).
      PeteS in CA
      • davmax
        • Dec 2005
        • 899
        Example cap. http://www.altronics.com.au/index.as...=item&id=R6900
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • tvtech
          • Oct 2006
          • 48
          I encontered these multisection ac rated lytics in a early 50's 12" stromberg-carlson tv,that had the am/fm radio built in.What a monster that set was,the chassis weighed at least 50lbs alone The power transformer was giant,because the set had two 5u4's in the power supply.Not to mention the hv section had two 1b3's.That was honestly the most complex tube set I ever restored.Now as for your capacitor problem you should be able to replace those with film capacitors of the appropriate value/voltage.You should be able to find those film capacitors at anitque electronic supply, www.tubesandmore.com
          • PeteS in CA
            • Aug 2005
            • 3586
            IIRC, the tubes in early tube TVs had have their filaments in parallel, which added to the mass of that transformer.
            PeteS in CA
            • Maxxarcade
              • Jul 2006
              • 973
              I found what I needed at Digikey. I'm going to use Metalized Poly caps.
              See a quick video here:
              http://www.youtube.com/watch?v=gNVOpESi9uQ
              • Maxxarcade
                • Jul 2006
                • 973
                Some progress... Notice the leaking cap on the end
                Before:
                After:
                Now I just need to find some low DC leakage 10uf 50v caps for the audio circuits. They are UCC LL series now, but I don't know if Panasonic FC is good enough. The UCC LLA's are the only low leakage ones I can find, but they are hard to get. Digikey doesn't have them even.
                • tvtech
                  • Oct 2006
                  • 48
                  Yep although cheaper sets had them in series string and a single or double selenium diode line doubler power supply,therefore eliminating the power transformer.
                  • PeteS in CA
                    • Aug 2005
                    • 3586
                    Those selenium rectifiers looked really interesting.
                    PeteS in CA
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      What selenium rectifiers?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        selenium rectifiers also smell wonderful when they fail.which they often do.
                        btw tried to kill the dupes but should have moved them instead of deleting.
                        • PeteS in CA
                          • Aug 2005
                          • 3586
                          We got onto talking about early TVs, Maxx. Selenium is a semiconductor that was tried in the 50s. The selenium rectifiers used in TV sets were basically several series-connected diodes (to get the needed reverse voltage rating) in an assembly. Each diode looked like a flat, square, plate, and there were small spacers between each plate that made the electrical connections. I think the intent in that construction was to have decent cooling. The hope was for rectifiers that could handle the power of a 5U4G (later, GB) that would last longer than a tube. The things were a bit leaky, and I'm not sure they delivered the improved reliability. IIRC, selenium was (in the US) declared a strategic material for the military, and set mfrs reverted to 5U4GBs or switched to silicon diodes, which were becoming available. I remember seeing ads for silicon replacement rectifiers that were packaged to fit in tube sockets and also in a form-factor for replacing selenium stacks. TV service people (I learned most or all of this from old magazines for TV service people) were cautioned to be aware that the B+ voltage would be higher, as the silicon rectifiers had a lower forward voltage drop.
                          Those were interesting days ... vacuum tubes (octal and "miniature"), multi-section lytics (finding exact replacements was not easy, even then, and lytic reliability sucked), point-to-point wiring with chassis mounted tube sockets (no printed circuit boards!), 150V-200V unregulated plate voltages, transistors and semiconductor diodes were just coming into use, customers who tried to fix their own sets by tightening loose screws on the chassis of their set (the adjustment screws for the ferrite slugs in tuned circuit transformers and inductors!), service people always troubleshot to the component level (they had to) and it was cheaper to do repairs than to toss-and-replace.
                          PeteS in CA
                          • PeteS in CA
                            • Aug 2005
                            • 3586
                            I remember two of the mfrs of selenium and silicon rectifiers ... Sarkes-Tarzian and International Rectifier. In the 70s and 80s, IR created the first commercially viable power MOSFETs and got out of rectifiers in the 80s.
                            PeteS in CA
                            • Maxxarcade
                              • Jul 2006
                              • 973
                              I'm quite familiar with tube electronics, I've rebuilt a couple tube sets. I just didn't catch the part where you started talking about selenium until I read further up. I thought you were saying there were selenium rectifiers in the pics I posted. It's almost noon and I haven't been to bed yet, so I'm a little out of it
                              The first radio I rebuilt and had it work well, was my Grandma's Philco model 46-420. It is one of the transformerless sets, with the 50B5 output tube, and all filaments in series. I think it had a tube rectifier though.
                              Right now I'm getting ready to rebuild a Sony TC-200 reel to reel, that has a tube/transistor hybrid amp, oil caps, all kinds of fun stuff. I'm a bit concerned about the rubber drive wheels though. They are in bad shape and I doubt it would be worth the cost of replacing them.
                              • starfury1
                                • May 2006
                                • 1256
                                I used to have one kicking around here but seems its gone
                                anyway goolged some pics for those wondering what a Selenium rectifier is
                                http://commons.wikimedia.org/wiki/Im..._rectifier.jpg
                                http://ampex.hughescatalog.com/elect...enium%201.html
                                This is just an interesting link by its self on old tech
                                http://www.xcvcorp.com/Electronics%20Museum%20HTML.html
                                somewhat interesting too
                                http://www.theodoregray.com/PeriodicTable/Elements/034/
                                for those who want a trip down memory lane and for those who are wondering what the old hands are waffling about
                                Cheers
                                You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                                • PedroDaGr8
                                  • Oct 2006
                                  • 130
                                  Maybe because SeO2 (likely product of selenium burning) is highly poisonous.
                                  From the MSDS http://www.jtbaker.com/msds/englishhtml/s1130.htm
                                  Health Rating: 3 - Severe (Poison)
                                  Inhalation:
                                  Highly toxic via inhalation. May cause severe breathing problems that may not appear for several hours after exposure. Irritates the upper respiratory tract. May cause headache, fever, chills.
                                  Typically, most poisons smell horrible (evolution) hence most sulfur compounds smell bad H2S and many others are quite toxic.
                                  • starfury1
                                    • May 2006
                                    • 1256
                                    Dont think they cared too much in those days about health or the environment for that matter.
                                    its even been used as part of the plot in a movie, the old selenium rectifier
                                    How much poetic license has been taken I don't know...they were a bit before my time and old tech then so don't really know much about them and chemical construction (although I don't think the scrappings off one would do what they claimed...but I don't know for sure)
                                    http://antiqueradio.org/tvshow.htm
                                    check "toxicity" under this link for Thallium
                                    Applications: used in semiconductor materials for selenium rectifiers,
                                    http://en.wikipedia.org/wiki/Thallium
                                    one word of warning thought.
                                    Seems you cannot just replace them with diodes,
                                    you need to add resistance.
                                    so be advised to check this out if you ever need to replace one I guess
                                    please keep us posted on how you go Maxxarcade
                                    Cheers
                                    • gonzo0815
                                      • Feb 2006
                                      • 1600
                                      I have had a lead acid battery charger with selenium rectifiers. The Rectifiers also functioned as an over current protection, if battery was empty.
                                      It was an nice an robust unit which does the job.
                                      • PedroDaGr8
                                        • Oct 2006
                                        • 130
                                        Cheers
                                        I know how bad thallium smells. We used to make a compound in one of my labs using Thallium (before we came up with a better route) and in the last step the thallium is eliminated from the compound, we just said it shitted the thallium out because it smelled so bad.
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Cama
                                          Solar Inverter - SMH-II - 2 missing capacitors
                                          by Cama
                                          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                          My model is : EASUN SMH-II 7 KW
                                          Mother Board : P/N 18947-002401250250
                                          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                          Thank you...
                                          09-12-2025, 02:50 AM
                                        • Ady2017
                                          Are there any datasheets available for Elna RJG capacitors?
                                          by Ady2017
                                          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                          05-25-2025, 02:19 PM
