Pioneer VSX-1021-k
  • NickLoC
    • 80
    Re: Pioneer VSX-1021-k
    OK. Sorry not a pro here. I know i see allot of times they say to pull the part to test fully. I normal try to test without pulling lol
    • NickLoC
      • 80
      OK. Thanks for the info.
      • mmartell
        • Oct 2013
        • 3189
        Just set your meter to continuity (beep) test and touch the legs in various combinations. There should be no sustained beeping.
        • mmartell
          • Oct 2013
          • 3189
          Ya me neither but since we aren't repairing Life Support systems I feel ok giving out what little nuggets I may have picked up along the way
          Do the above test with unit unplugged btw.
          • tibimakai
            • Jan 2012
            • 3680
            You may have to remove a board or two on top, but you should be able to reach the transistors.
            • NickLoC
              • 80
              All seem to test fine. No shorts. Am I missing something?
              • CapLeaker
                Leaking Member
                • 8005
                I wonder if there is proper power to the amp board?
                Is the FL OFF light still blinking as indicated in post one?
                Cording to the manual:
                There is a problem with the receiver's power unit or fan. Try turning on the power. If the same thing happens, the receiver is damaged. (Other symptoms may appear when the power is turned on.)
                • NickLoC
                  • 80
                  No fl light blinking. Just mcacc light. The amp started acting up awhile ago. Would work great for a while, then click off and fl light flash. Now it's the mcacc light
                  • CapLeaker
                    Leaking Member
                    • 8005
                    Hmm... O.k. Different approach...
                    Service manual page 34. Put the amp in "test mode" and see what code she gives.
                    Service manual page 32, 5.3 Overload and DC Protection circuit. What is the voltage on IC3004 on pin 71 and pin 80?
                    By the way... did you have the amp totally assembled correctly before testing? If not the protection circuit will be activated. That's on page 38.
                    • NickLoC
                      • 80
                      Will have to try that later. Will let you know
                      • NickLoC
                        • 80
                        So that is on the HDMI board? How do I test the pins on that ic? Really small. And when? Do I have to try and turn it on and read it within a certain time?
                        • CapLeaker
                          Leaking Member
                          • 8005
                          Look at page 32 and 33 on the SM. IC3004 is on the face somewhere (front assembly). You can chase that through a few boards ending on the amp board.
                          I'd like to see the protection code the amp is shutting down with, to see to what pin guide you to. Other than that, you have to read page 31 on the SM and check the pins that are mentioned there. To measure the pins, have the DMM set to DC, negative lead to chassis GND, put positive probe on pin 80 and turn the amp on. Observe the readings for 10 seconds. Do the same on pin 81.
                          Instead of chasing through the pins on the IC, you also could find the DCDET lines on the amp board (page 32).
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4922
                            • New Zealand
                            #33
                            Yes, to check a component 'properly' it must be done out-of-circuit, because other parts in parallel may throw off any measurements.
                            BUT, when a part is shorted, it is very obvious. Doesn't matter what is in parallel with a short, it will still read short when you measure across it.
                            Imagine as if you were trying to measure a resistor (any value) while your probes are shorted together with a piece of wire...
                            Once you find a part that appears to be shorted, you would of course remove it, and test again to ensure you are correct. If the part then did NOT appear shorted, you would look for something else shorted in parallel with it on the board.
                            -David VanHorn
                            • NickLoC
                              • 80
                              Still have not had time to test further. Guy on eBay says the amp board is good and they tested it and says the amp board is not shorted. So will be doing the test stated here when I have some time
                              • CapLeaker
                                Leaking Member
                                • 8005
                                Unless I know what I asked for on post #29, we are stuck. The error signal has to come from some where.
                                • NickLoC
                                  • 80
                                  Pin 80 on ic3004 reads 0 volts. Pin 71 reads 4.5 volts. Un plugged connection from the IR board that connects to the amp board and I get an amp overheat error. Plugged back in the amp just shuts down. No error code. Can not get into service mode. Amp shuts down trying to.
                                  • CapLeaker
                                    Leaking Member
                                    • 8005
                                    unplug it again and see if it comes back. unfortunately the SM just sez "other trouble" to that new fault. All you can do now is verify your cabling... maybe something isn't correctly plugged in... dunno...
                                    • NickLoC
                                      • 80
                                      Does anyone know what the specs are on the out put of the main transformer? Would like to test it. What voltage an i supposed to see on those two pins on that ic?
                                      • Jefftra2
                                        • Apr 2016
                                        Trying to find out if you ever resolved your issue. A friend of mine gave me his VSX1021k with the MCAAC red light flashing and I'm trying to fix. If I release from protected mode, it powers on for about 3 seconds and back off. I removed the entire amp board from the unit, when I turn it on without it, the error message says amp overheat. Not sure if that tells me anything. Are the final transistors the ones attached to the heat sink? One post mentioned if you find a shorted transistor then cut the legs off. Would this be to separate from the board temporarily to see if it will power on? Where can I get a new transistor if I have a defect one?
                                        • dobrykamil
                                          • Jun 2013
                                          • 62
                                          Looks like you have exact same issue as I've had with my VSX-527. I guess your model has 2 protection lines too, one for front and possible center speakers and the second line for back and surround speakers. If you switch it on without amp board,unit will display OVERHEAT error. Resetting to default settings doesn't clear that error.I believe, the main microprocessor still "remembers" that something has happened before at the power transistors level, and will not work until it gets the "signal" (like 0.4-0.6V) from working pair of power transistors. Once I've replaced them (front right channel in my case) the error was gone and unit start to work again.
                                          • burntonnerings
                                            Pioneer VSX-1021 MCACC flashing, can't find problem
                                            by burntonnerings
                                            Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
                                            If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
                                            Entering reset mode and executing a reset doesn't change this.
                                            I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
                                            12-09-2023, 10:11 PM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • abajor
                                            Canon VIXIA HF S10 A read data from inernal flash memory.
                                            by abajor
                                            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                            I think my best shot is to figure out a way to read the internal flash memory outside...
                                            07-20-2024, 12:04 AM
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
