Pioneer VSX-1021 MCACC flashing, can't find problem
  • burntonnerings
    • Dec 2023
    • 11
    Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
    If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
    Entering reset mode and executing a reset doesn't change this.
    I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing.
    No DC voltage present on any speaker outputs.
    Checked for shorts on all of the output transistors attached to the heat sink - they're all fine.
    No physical evidence of bad caps or burns or anything on the amp board.
    Read some of the other VSX threads but still not clear what to check next.
    Any thoughts?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8344
    Try powering the receiver up and press and hold the tune down and multi-zone on off buttons down at the same time. See what she does.
    With amps, you always look for you power rails and the PA stages. Do you hear a relay click when you turn this turkey on? If not, that explains when you don’t measure anything on the speaker outputs.
    • burntonnerings
      • Dec 2023
      • 11
      Thanks - that procedure is the "release mode" I referred to in my post - powers up, behaves normally for about 3 seconds, shuts down to MCACC flashing
      Relay clicks, but I'm assuming that is to disconnect the outputs from any DC present on the output stage.
      Will find a service manual and test the rails.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8344
        If memory serve me right, I thing this amp has grounding points on the bottom of the main PCB. So if you take that PCB out and don’t jumper the proper ground points, it will go into protection mode as well.
        • burntonnerings
          • Dec 2023
          • 11
          yes - but its going into protection mode even before I disassembled it.
          found a service manual, so going to check out what the supply voltages should be for the amp board
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8344
            Did it say any error codes beside the flashing mcacc?
            • burntonnerings
              • Dec 2023
              • 11
              Nope - and I am unable to enter the service menu to see the error count for each code.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8344
                Hmm… that’s something new, usually they greet you with an error message of something. Is there a history that goes with it? Usually the MCACC has something to do with the output section. When you checked the finals, did you check the driver and pre driver? Try taking a measurement direct at the output, before the protection relay and turn it on. You may have to use the min /max setting on your DMM.
                • STKR123
                  Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                  by STKR123
                  As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                  I wonder if re-flashing the BIOS might be of any use here.
                  As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                  There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                  11-03-2024, 06:58 AM
                • EduCabral
                  [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                  by EduCabral
                  I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                  While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                  🔧 Details:
                  • Model: YT-M06
                  • Interface: Pioneer 1
                  • MCU: Fujitsu MB89F202
                  • Goal: Find a valid .bin firmware file or memory dump from a working unit
                  I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                  07-15-2025, 12:26 AM
                • learnmore
                  Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                  by learnmore
                  Hello Community!
                  CASE DETAILS
                  Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                  13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                  Tried inserting firmware on USB and left it in for a few hours, but no change
                  03-03-2024, 09:49 AM
                • danielgerman681
                  ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                  by danielgerman681
                  Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                  08-27-2025, 01:17 PM
                • HTR-Informatique
                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                  by HTR-Informatique
                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                  I also changed the screen because the PC fell and the screen was broken.
                  I changed the battery with a new and original battery.
                  I also had corrosion/oxidation on the...
                  02-09-2025, 06:51 AM
