Pioneer VSX-1021-k
  • NickLoC
    • 80
    Pioneer VSX-1021-k
    So my amp was working, but would cut out while listening to it. Then the "FL Off" light would flash. Finally it will just turn on, then after a couple secs it will click off and the "MCACC" light will flash. Tried doing the release mode and it will try to power back up but do the same thing. I just replaced the AMP board and it does the same thing. Could it be the Main PCB with the speaker connectors on it? I tested the voltage from the power board and it seems fine.
  • NickLoC
    • 80
    Re: Pioneer VSX-1021-k
    Does anyone have any ideas on this one? I have the service manual
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8331
      Did you do a master reset yet? Or did you mean with release mode the reset? Any error codes that you can retrieve? FL Blinking and MCACC usually means you've blown something in the output stage. So I would think it is in protect mode.
      • tibimakai
        • Jan 2012
        • 3680
        Usually, the first thing that I'm doing, when I open a receiver like this, is to check all the final transistors for short.
        • NickLoC
          • 80
          I did a release mode. The amp board was replaced. As far as finall transistors are you talking about on the speaker board? When I plug it in the mcacc light just flashes. If I release it, it powers on them after a few secs it clicks of and the mcacc light just flashes
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8331
            there is a short in either the finals or in the drivers. There is DC on the outputs and that's why the amp shuts down and goes into protect mode (mcacc light blinking), no sound.
            • tibimakai
              • Jan 2012
              • 3680
              Check all the final transistors, mounted to the heatsink and if you find shorted ones, cut all there legs and then try to turn it on.
              • NickLoC
                • 80
                I have replaced the amp board, the one with the heat sink. So could it be these ones?
                • mmartell
                  • Oct 2013
                  • 3189
                  Where did you get the replacement amp board ?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8331
                    No, not that board. It would be that what you have replaced (the board with the large heat sink on it). I've managed to get the service manual for it and it says exact that, what I said in post 3. You can read it yourself on page 31.
                    For some reason I can't upload the SM right now, so here is the link:
                    You have to wait like a minute in order to actually get the down load link on the bottom. Wait for the "Get manual" link.
                    So you are down to testing the finals.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Yes, you should to a reset first.
                      On the 1122k, is Tuner up and Multizone on/off for 5 seconds.
                      Don't remember what is on 1021k.
                      Here is one on Youtube:
                      https://www.youtube.com/watch?v=DSX5SrZgrkU
                      • NickLoC
                        • 80
                        I got the board on eBay. I know it's possible to get bad parts. I just hate to ship it back. Can't go cutting on a part if I need to return it. I'll try the reset. So this is the only possibility? I do know it's going into protect mode. I do have that service manual already.
                        • NickLoC
                          • 80
                          Tried reset and it fails. Have to do release mode to get it to turn on, then immediately turn it off before it goes into protect mode. Then I held enter and standby, it asks if I want to reset, and before I can hit yes it clicks off with the mcacc light flashing.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8331
                            either the driver, the final or both in one or more channels has a short. That puts DC on to the output terminals. In order to save your speakers there is a relay. If it detects DC, it won't click and hook up the finals to the speaker terminal. Could be that on top of the blown final, bad resistors and zener diodes are toasted too. Not sure if you are comfortable fixing that or not.
                            • NickLoC
                              • 80
                              So looks like I need to send that amp board back? I have replaced parts before. Was hoping this would be an easy fix to just replace the whole board.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Measure those transistors for short.
                                We said this already a couple of times.
                                • NickLoC
                                  • 80
                                  Will do that. But I have a limited time for refund. If any part of the board is bad I must send it back. Sorry haven't had time to test. Thanks for the info. Will post back after testing
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Are the transistor legs not accessible from the top ?
                                    • NickLoC
                                      • 80
                                      No. On the bottom. I can only test them in place on the board. I know I need them out to test properly, but if I mess with the board I void the warranty on the part. That is my problem. I think I will send the board back and then test the old one I pulled. Then I can desolder parts and test properly.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Bah if they're shorted you won't need to take them out to test them.
                                        • burntonnerings
                                          Pioneer VSX-1021 MCACC flashing, can't find problem
                                          by burntonnerings
                                          Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
                                          If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
                                          Entering reset mode and executing a reset doesn't change this.
                                          I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
                                          12-09-2023, 10:11 PM
                                        • ekozeko333
                                          by ekozeko333
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • spmetroil
                                          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                          by spmetroil
                                          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                          I have a CH341A programmer and I already attempted the following steps:
                                          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                          08-19-2025, 09:23 AM
                                        • abajor
                                          Canon VIXIA HF S10 A read data from inernal flash memory.
                                          by abajor
                                          Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                          Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                          The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                          I think my best shot is to figure out a way to read the internal flash memory outside...
                                          07-20-2024, 12:04 AM
