I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
Here’s what I’ve done so far:
I’m attaching a short video of the behavior :
https://youtu.be/lzmcI9jLVPY
and also the full service manual in case anyone wants to check the schematics or pinouts
Any ideas are welcome — thanks in advance!
Seven
- Fully opened and cleaned the unit (a lot of dust inside)
 - Removed and visually inspected the AMP board → nothing visibly damaged or burned
 - Testing is done with nothing connected (no speakers, no HDMI, etc.)
 - Only once it powered up normally and worked for around 5 minutes, then went back into protection
 - I tried disconnecting the BN704 connector (carries DC_DET, ASO_DET, THERMAL signals from the AMP board) to test if the AMP board was responsible
→ But I’m not sure whether disconnecting BN704 might itself trigger protection, or if it actually isolates the AMP correctly
Seven
 The blinking light means you got trouble with the PA. Either it has a short / over current condition, or there is an open or not fed power somewhere on that board.
