Denon AVR-X4000 – Fast red blinking after 2nd relay
  • SevenOFF
    • Jun 2025
    • 5
    • France
    I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
    According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
    Here’s what I’ve done so far:
    • Fully opened and cleaned the unit (a lot of dust inside)
    • Removed and visually inspected the AMP board → nothing visibly damaged or burned
    • Testing is done with nothing connected (no speakers, no HDMI, etc.)
    • Only once it powered up normally and worked for around 5 minutes, then went back into protection
    • I tried disconnecting the BN704 connector (carries DC_DET, ASO_DET, THERMAL signals from the AMP board) to test if the AMP board was responsible
      → But I’m not sure whether disconnecting BN704 might itself trigger protection, or if it actually isolates the AMP correctly
    I’m attaching a short video of the behavior :
    https://youtu.be/lzmcI9jLVPY
    and also the full service manual in case anyone wants to check the schematics or pinouts
    Any ideas are welcome — thanks in advance!
    Seven
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Look hard on all the connectors on the PA board (with the big heat sink) and check every connector. Maybe it is simple as a wire pulled out of a connector or a bad solder joint.
    • SevenOFF
      • Jun 2025
      • 5
      • France
      Hi, already checked the PA board and looks fine and i've disconnected bn704 and it's still doing the red light so i think that the PA Board isn't the issue but not sure
      here is a few pics :
      edit : i've removed the whole PA Board from the denon and it's still doing that so i don't think the PA Board is the issue lol
      • SevenOFF
        • Jun 2025
        • 5
        • France
        okay so small edit, after i unplugged the whole amp board didn't see but it blink red but slower this time sooo i'm lost rn ;-;
        https://www.youtube.com/watch?v=yAoLvnDXHI8
        2nd edit : i tried to start it after that i've recorded that video, after a few minute plugged in with the red blinking light, i had the power amp disconnected and it worked for a brief amount of time like 10s until a 3rd click happend sooo i'm pretty sure it's either the PSU board or the main board
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8340
          Why would you start the amp without the PA? The blinking light means you got trouble with the PA. Either it has a short / over current condition, or there is an open or not fed power somewhere on that board.
          Download the Service Manual and go through the troubleshooting steps. Start with all the little power supplies and make sure they all there and working to spec.
          • SevenOFF
            • Jun 2025
            • 5
            • France
            the issue can be the PA but it can be the PSU board too or the main board no specially the PA from what i've read, i've checked the transistor with a multimeter and it seem fine, and i've tested some small resistor seems okay too giving the right amount
            • dobrykamil
              • Jun 2013
              • 63
              Put the amp board back and attach all cables. Black probe on the chassis, red on any pin of the brown, bias connector. Switch avr on. With working channel, you should have there 2-30mV. Do this for each channel. A rapid flashing LED, means DC protection. If you disconnect amp cables, over current protection will kick in (slow blinking LED). It's a Denon's thing. Once you find faulty channel, let us know, what voltage are you getting on bias connector. If it's positive value, then check KTC3206 transistor, as they quite often fail.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • pc_okay
                LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
                by pc_okay
                Hello friends,
                I have this laptop AMD Platform starting & not posting, fan spinning.
                When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
                If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
                I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
                CPU and his area heat, maybe the cpu is dead?
                10-21-2024, 10:23 AM
