Mysterious noise on audio tape
+ More Options
Posts
  • Tom41
    • Oct 2005
    • 336
    • England
    Not really sure if it's the right place to post this, but here's something very strange. I got a brand new audio cassette out of its plastic packaging, put it in my recorder, and recorded a radio programme onto it. The programme didn't fill the tape, but the next episode wouldn't fit on that side as well - so I decided to fast forward to the end so I could use side B.
    This particular tape recorder has a search function. That is, if it 'hears' a signal on the tape after a long silence while you're fast forwarding, it'll stop there and play the tape.
    Shortly before the end of the tape was reached, the recorder stopped forwarding and started playing. I heard a low, wavering buzz coming out of the right speaker for about 8 seconds, then it cut off. Rewinding the tape a bit, I discovered that the noise was actually on the tape itself, not from the equipment.
    This tape is brand new and has never been recorded (or even played) before, except for that radio programme that used up part of one side. The area with the buzz had never been recorded before!
    Do factories sometimes put signals onto obscure areas of the tape for testing purposes, before sending them out to shops? If it hadn't been for the search function of my tape recorder, I never would have noticed and probably would have recorded over it later on!
    Here's a recording of the sound, if you're interested:
    http://tomsonic.dyndns.org/temp/tapenoise.MP3
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Harvey
    • Apr 2007
    • 264
    Re: Mysterious noise on audio tape
    You can often hear a similar noise to yours at the end of side one on pre-recorded tapes, and its a marker used to tell the splicing machines were to cut the tape.
    Not sure why that would be on a blank tape though, as its simple to measure the amount of tape on each spool to know where to cut it.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Many years ago when I still used tape I found and odd one too. It was from TDK. The tape was brand new and still in its wrapper. I put it in the deck just to see what kind of background noise was on a new tape. It didn't have "noise" on the A side at all. It was recorded end to end with classical music! I never figured this one out. I think that maybe it was used as a QC test tape or someone was playing a joke. Why would they put a test tape back on the production line anyway?
      Mark Twain
      John Paul Jones
      Rod Serling
      • tazwegion
        • Jun 2006
        • 444
        Oh how disappointing, I clicked on the thread hoping it would be something relating to EVP
        FWIW I've purchased audio cassettes (back before CD's) and found a slight trace of something other than the recorded album at the end of side A
        Viva LA Retro!
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          if i were to pull such a prank i would have recorded some record backwards or something.iirc it was called backmasking.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • RetroComputingGrotto
            IBM LTO 7 Tape Drive - Dust Sensors??
            by RetroComputingGrotto
            I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
            I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
            09-19-2024, 01:54 AM
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • triplefour
            LG 75UN8570AUD panel issue fixed with tape.
            by triplefour
            I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
            add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
            07-17-2023, 10:22 PM
