Converting RX-V373 110v to 220V
  • Alphas
    • Jun 2014
    • 3
    • Earth
    Anyone does it, I have the schematics but there are quite a number of components to add?
    And the power transformer seems to be the killer
    Re: Converting RX-V373 110v to 220V
    Unless the primary side of the transformer has dual windings, then there is not much you can do.
    • R_J
      • 9594
      Get a seperate step down transformer with the proper wattage and just use that.
      • t4796
        Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
        by t4796
        I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
        Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
        From the FAQ I learnt that for 110v the power...
        10-25-2024, 06:59 PM
      • maleksa
        Yamaha SY85 power board 220v or 110v?
        by maleksa
        I need help to ascertain if the power supply on my Yamaha SY85 keyboard is 110v or 220v or both.
        I have attached the schematics below....
        07-01-2023, 08:49 PM
      • sansonet
        Converting 12VDC transformer to 12VAC
        by sansonet
        I need an AC transformer because the one I used is burned. Since I have some unused DC transformers, I wonder if it is possible to just remove the bridge rectifier from it to convert it to an AC transformer. I measured voltage before the rectifier on this one - it shows 13 VAC, and 16 VDC at connector without load. Rated 12VDC 1000mA....
        06-29-2023, 03:20 PM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
