Harman Kardon 395 Sub Woofer & Satalite speakers
  • groovejet
    • Feb 2014
    • 19
    I ve noticed a change in the quality of sound from my Hk 395 speakers.
    The 2 satalite speakers seem fine, its the sub woofer i thinks to blame?
    When turning the woofer volume pot there's a lot of distortion / crackling.
    Also this week, when i was watching a movie there was also heavy distortion on the lower bass sounds, with a lot of vibration.
    I noticed taking the back off the speaker seemed to ease the unwanted noise, and then i noticed a couple of caps i wasnt happy with!
    I tested these with a multimeter as i hav'nt got a esr meter. My readings were pretty suspect, as i could'nt differentiate from a leaking cap of glue type substance from manufacture?
    Anyway i changed these caps (25v 470uf) (50v 2.2uf) and what do you know? A big improvement.
    I thought i'd got it but couple of days later i heard more distortion??
    From what a friend said the caps on the board were audio ones and i changed them to something else?? (They were blue color, i changed to black ones)
    Now? Ivé stripped the speaker down and removed the volume pot and trebble pot from the board, and im going to swap them over!
    My thoughts were that the volume pot has had more hammer than the trebble, so changing them will give me decent volume control.
    But i want to clean them up also? Markings on them say B503
    Any help to get these bad boys working 100% most appreciated
  • lti
    • May 2011
    • 2548
    Re: Harman Kardon 395 Sub Woofer & Satalite speakers
    Cleaning the potentiometers will help. Spray contact cleaner in them and turn the shaft until it turns smoothly. It will feel rough after the contact cleaner is sprayed in.
    Replacing all the electrolytic caps is a good idea. Harman/Kardon used the cheapest caps they could find back then, and their amps run warm. I had to recap some little HK-206 speakers a few years ago. Just use good 105°C caps like Nichicon VZ series. The old ones definitely weren't audio grade, and you don't need audio grade caps anyway.
    I think B503 indicates a 50K ohm linear pot.
    • Kiriakos GR
      Banned
      • May 2012
      • 940
      • Greece
      In audio you need branded caps and not 105°C, they make no difference.
      I have Yamaha http://usa.yamaha.com/products/audio...ems/ystm20dsp/ which need recaping 100%.
      • lti
        • May 2011
        • 2548
        You're right. This amp probably doesn't get hot enough to need 105°C caps. Good quality caps will last longer than the originals, no matter what the temperature rating is.
        • groovejet
          • Feb 2014
          • 19
          Removed the pots.
          The volume pot was clean but when i pulled back the metal tabs holding it together i noticed very small pieces of the plastic body cracked off.
          This broken part would of held it secure in its metal enclosure, which is why there was so much interference.
          Anyway i havnt got replacements and its Sunday so i stripped, cleaned and put them both back together, then swapped the dodgy one for the treble pot which doesnt get any use.
          Works much better, although at very high volume a problem still exists. Its a vibrating popping noice(pissing me off)
          Thanx for help up to now
          • groovejet
            • Feb 2014
            • 19
            How do i identify good and bad caps?
            Meaning good quality made ones?
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              By comparison of their named specifications ( specs sheet) by using a 200$ portable LCR bridge.
              • lti
                • May 2011
                • 2548
                If you're wondering what brands are good, look here:
                https://www.badcaps.net/forum/showthread.php?t=414
                Anything from those brands (except Mallory - they're made by Teapo now) will work. You don't need expensive caps.
                There is the possibility that one of the chips is bad, but changing those cheap caps would be good to try first. I don't know exactly what kind of noise you're talking about. If there is a constant hum in the background, replace the caps. Other types of noise could be caused by bad caps or another component failing.
                • JJR
                  • Mar 2013
                  • 171
                  Panasonic & Rubycon caps here http://cpc.farnell.com/aluminium-ele...etResults=true
                  Both top quality & free delivery from CPC Farnell.
                  • groovejet
                    • Feb 2014
                    • 19
                    I know its difficult to explain the types of noice im experiencing over a thread, but thanks for all the help thus far
                      You can improve the power supply peak current demand by changing that 470uf 25V filter cap to one with low ESR and higher current ripple spec, you can also go to 680uF if it will fit the board.
                        BTW, you should also remove those brown glues.
                        • groovejet
                          • Feb 2014
                          • 19
                          I will remove glues but Why??
                          The 2 poly caps closest to the heat sink were stuck together. I pulled apart to check whether they were leaking or were actually glued!
                          So my question ....Why glue these 2 and not other components? Whats the reason for all this glue, because it doesnt seem to be helping in any way?
                            https://www.badcaps.net/forum/showthread.php?t=34692
                            They use glue to hold down components during wave soldering process.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              470uF only? For a speaker setup like this?! Man, that's some cheap build quality there. I wouldn't go with anything less than 2200uF. If the cap doesn't fit on the board, it's okay to have it sitting high on its legs. After all, this is not high-frequency PSU, so ESR and long leads won't affect the operation.
                              Then again, that transformer is puny too!
                                @2200uF it may trip the fuse due to high inrush current, have to measure the inrush current to find out.
                                • lti
                                  • May 2011
                                  • 2548
                                  I think C34 (the largest cap on the board) will be the filter cap. It's at least 2200uF, based on its size. There's no way that the filter cap is only 470uF. Even the little HK-206 speakers (using a TDA1517) have a 2200uF cap in the AC adapter and an extra 470uF cap next to the power input jack in the amp. This isn't Cyber Acoustics.
                                    From post 1 "Anyway i changed these caps (25v 470uf) (50v 2.2uf) and what do you know? A big improvement" unless he did not change C34 which is the big filter cap.
                                    You may be right that it is 2200uF based on the size of the rectifier diodes and the heatsink, the 470uF will not be able to handle the current demand.
                                    • poconoman
                                      • Feb 2015
                                      Hi all, great site!
                                      Was wondering, what size woofer is in the hk395 subwoofer and would upgraded driver improve the bass? If yes, what woofer do you suggest?
                                      Thank you!
                                      • PowellSkier
                                        Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                        by PowellSkier
                                        A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                        06-17-2024, 11:43 AM
                                      • funky2x
                                        Harman kardon onyx studio 7 Smd code
                                        by funky2x
                                        Cant find what smd code Y0DVA.
                                        sitting in Harman kardon onyx studio 7. Appreciate any help.
                                        05-29-2025, 03:44 PM
                                      • PowellSkier
                                        Cement resistor swap in Harman Kardon AVR
                                        by PowellSkier
                                        Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                                        06-04-2024, 06:41 PM
                                      • falafinasul
                                        Harman Kardon AVR 3700 Fonte queimada
                                        by falafinasul
                                        Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
                                        I made a new Diagnostic and verified that the input source is shorted.
                                        Someone help
                                        02-24-2023, 05:51 PM
                                      • BlackScreen_22
                                        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                        by BlackScreen_22
                                        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                        I had no problems connecting mosfets and capacitors,...
                                        08-27-2024, 12:46 PM
