Harman Kardon AVR 3700 Fonte queimada
  • falafinasul
    • Feb 2023
    • brasil
    Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
    I made a new Diagnostic and verified that the input source is shorted.
    Someone help
  • petehall347
    • Jan 2015
    • 4451
    Re: Harman Kardon AVR 3700 Fonte queimada
    please explain input source
    • PowellSkier
      Harman/Kardon AVR 645 returning to stand-by after a few seconds.
      by PowellSkier
      A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
      06-17-2024, 11:43 AM
    • funky2x
      Harman kardon onyx studio 7 Smd code
      by funky2x
      Cant find what smd code Y0DVA.
      sitting in Harman kardon onyx studio 7. Appreciate any help.
      05-29-2025, 03:44 PM
    • reessi
      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
      by reessi
      Hello:
      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
      I started on the ACER:
      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
      10-29-2024, 11:31 AM
    • PowellSkier
      Cement resistor swap in Harman Kardon AVR
      by PowellSkier
      Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
      06-04-2024, 06:41 PM
    • dvd4me
      Harman Kardon AVR 3700 blown standby power
      by dvd4me
      This is a new iteration of the same issue with the standby power being defective. Based on the past users experience and the AVR 370 schematic I was able to finally found all the bad parts and slowly going to put this back together. As a short pro-log, the initial state of the fuse (8A) led me to take a cautious approach to this.
      Is never good to to replace the exact fuse and power back on, this is the worst approach.
      Instead, put a small 1A fuse and use Variac to slowly increase the voltage. I did this and the 1A fuse blow quietly at very low voltage, with...
      03-30-2021, 11:54 AM
