Pioneer amplifier A-205 Relay not clicking after a mistake i made
This topic has been answered.
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    #41
    btw there is actually a much cleaner version of the schismatics R_J shared it
    https://elektrotanya.com/pioneer_a-1.../download.html
    in case it helps
    • R_J
      • 9515
      Does the speaker switch have any effect? also do you have any headphones to try? The amp output runs through the headhphne ass'y board before it goes to the speakers.
      • GraphicMan
        • Aug 2018
        • 124
        • Egypt
        #43
        the speaker switches has no effect also , on top of that i never had any scratchy noises from the speaker switches also
        they are just A and B, i am always using the B, and it works but on right channel only
        i have an earphone but with the small jack, i think i have a converter, will try and let u know
        thanks
        • R_J
          • 9515
          I doubt there is a DC problem with the amp section, if there was the protection circuit would engage and you would not have any output. it is likely something in the signal path that is at fault. If you can access the plug AKP1044, use a metal pin held by your fingers to inject signal (hum) at pins 1 (right channel) and 3 (left channel)
          • GraphicMan
            • Aug 2018
            • 124
            • Egypt
            #45
            dont know if that is a good or a bad news, i did not find the converter so i used these 3 pins as mentioned in the pic and there is clear sound coming to the head phones from both left and right pins
            plz confirm that my assumption is correct on these pins
            this means there is no issue in the path of the input signal?
            if so, where is the problem then?!
            can you please guide me where is that AKP1044 connector on the actual pcb?
            attached is the pcb after cleaning and re flowing some joints (already tested and worked at that stage before the assembly)
            if the connector is not on that pcb where is it?
            thank you
            • GraphicMan
              • Aug 2018
              • 124
              • Egypt
              #46
              i also want to add a side note that i notice now and also before
              I am actually connected a tweeter and a sub woofer in parallel to every channel, i know u might disagree with that setup but that works perfectly and the tweeter is not overloaded or anything, however latetly before that thread , there was scratchy noises due to the switches as well as the pot, i cleaned these but one thing sometimes happen which is the tweeters works but not the subwoofer until i boost the volume and get it started then i can lower the volume normally, it could be from the pot or scratchy switches still but thought to mention that in case it means something else
              • GraphicMan
                • Aug 2018
                • 124
                • Egypt
                #47
                ok i found the connector u meant, it is on the pic i sent
                R makes sound, L no sound when touched!
                so?
                • petehall347
                  • Jan 2015
                  • 4423
                  • United Kingdom
                  #48
                  might mean the speaker relay contacts are dirty .
                  • GraphicMan
                    • Aug 2018
                    • 124
                    • Egypt
                    #49
                    it does not have a relay, perhaps bad contact also, good point from you
                    i just need to solve the L channel at the point, very annoyed
                    thanks
                    • petehall347
                      • Jan 2015
                      • 4423
                      • United Kingdom
                      #50
                      speaker switch then . cranking vol can make the connection better for a time .
                      • R_J
                        • 9515
                        Your first most mentions the relay
                        all lights are on normally, except that the unit does not click its relay anymore and ofcourse no sound
                        If you have audio at the headphone jack then I would start by resoldering the connections on the speaker switches and the connector pins as well
                        Looking at your picture of the headphone jack, it looks like the (L) contact needs to be resoldered I suspect others are bad on that board as well
                        • CapLeaker
                          Leaking Member
                          • 7986
                          Geez… should be easy finding the problem. The amp isn’t going into protection mode since the relay clicks. So the problem has to be after the amp board until it hits the speaker terminal. Plus the headphone jack, as it disconnects the speaker output. You can trace the audio either from leaving the PA board to the speaker output jack or backwards from the speaker jack back to the PA board. RJ already mentioned the speaker jack… didn’t read all the posts… lol And the protection relay itself, as it also physically disconnects the output to the speakers.
                          • GraphicMan
                            • Aug 2018
                            • 124
                            • Egypt
                            #53
                            hmm, this is getting a bit strange and also very frustrating
                            guess what
                            i re soldered all pins on the jack/speaker switches pcb as well as all the pins of the connectors on the attached pic (inside the rectangles)
                            and now i dont have any output on the speakers!!!, kept clicking on the speaker switches, nothing at all
                            on top of that, when i tested again with the headphones, the sound is very very faint! unlike the last time!!!!!
                            what does that mean?!!
                            • GraphicMan
                              • Aug 2018
                              • 124
                              • Egypt
                              #54
                              relay still works normally
                              • GraphicMan
                                • Aug 2018
                                • 124
                                • Egypt
                                #55
                                i thought to test the connectivity of these switches
                                B is perfect which is the one i am using all the time
                                A connect / disconnect only the one marked right, X is always ON no matter what
                                is that right or wrong? can this cause all that issues including the very faint sound on the phones?
                                i really dont want to pull these out unless i am sure it is the issue coz it is a lot of work
                                the 2 switches are both crimped to a single steel plate, for that i will have to desolder the 12 pins at the same time in order to be able to pull it out!
                                thanks
                                • GraphicMan
                                  • Aug 2018
                                  • 124
                                  • Egypt
                                  #56
                                  i am assuming that "x" issue (connected all the time) should not be the problem coz whether A switch is on or off the output is not affected as far as B switch is good and ON and that by itself is worrying me
                                  • GraphicMan
                                    • Aug 2018
                                    • 124
                                    • Egypt
                                    #57
                                    ok finally some good news
                                    i re soldered again and add a re flowing /soldering to the relay pins and some other pins that looks they have little solder (close to the connector)
                                    there is sound on both channels , but for few seconds and when i tried to press on the direct switch there was noises (which is not news, i know it have issues) but the news is that the relay started to go on/off quickly, so i decided to power off the unit immediately to check
                                    now i removed the direct switch
                                    and disassembled it, it is complex and have 12 pins!
                                    for that i need to know what is it doing first , so that i can check before re soldering it
                                    the main issue for me with these switches is that in addition to its 4 copper moving pieces there is also a small copper plate, i am not exactly sure what it does, apparently the unit cant work/produce sound with that switch being pulled out coz it has a function in both on/off states
                                    i have uploaded pics for the switch and also a drawn diagram which have 2 copies to make it easy for you to mark for me the connections should be made between pins on the OFF and ON states, plz pay attention to the orientation, the pins shown assuming a direct view not x rayed and the bulk is on left side
                                    lets finish this i hope
                                    thanks
                                    • GraphicMan
                                      • Aug 2018
                                      • 124
                                      • Egypt
                                      #58
                                      in addition:
                                      also here is a pic for the front panel, showing the 12 pins
                                      i would like to first solder them to the "direct switch" OFF state without using the switch, just to make sure and make it easy to diagnose
                                      plz let me know how should i blob / wire them without the switch, just mark for me the connected pins and i will do it
                                      thanks
                                      • GraphicMan
                                        • Aug 2018
                                        • 124
                                        • Egypt
                                        #59
                                        this is the best i could find with my limited knowledge in schematic drawings for the direct switch pins
                                        but here it is rotated compared to the pcb pic i shared, is the small + means connected together? and on which state is that? off by default
                                        just trying to learn something new
                                        thanks
                                        • GraphicMan
                                          • Aug 2018
                                          • 124
                                          • Egypt
                                          #60
                                          plz dont forget to tell me about these 2 pins specifically coz i did something, i desoldered both using the copper wick (completely clean) and i did test the switch (both pins isolated from the pcb), and it works perfectly it does d/c and connect them so the short is not from the switch, however when i test the pads continuity they are always connected, so i want to know if that is ok or they should not be connected all the time at any state
                                          the other pin does d/c / connect, the other B switch is perfect also, it is important coz it could mean something, however like i said keeping A on with B on fine and it have never been a problem but just want to make sure
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • jason123
                                            Pioneer VSX-523-K Amplifier - Identify resistors
                                            by jason123
                                            Hi folks,
                                            New audio equipment repair and I could use some help.
                                            Picked up VSX-523-K Surround sound amplifer.
                                            Upon power up for the first time (been sitting for a while) loud popping noise and smoke..
                                            Disconnected, opened up and found many popped caps on the amplifier board.
                                            Replaced all, replaced A992 BJT, and pre-amp transistor and power transistor. I found 0.47 Ohm resistors that are blown or have gone High impedance and I'd like to replace.
                                            On the service manual, it shows these as 0R47(2) (assuming this is a 0.47 Ohm, 2W?)...
                                            09-14-2021, 10:16 AM
                                          • MrCommunistGen
                                            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                            by MrCommunistGen
                                            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                            07-12-2021, 05:11 PM
