Luxman R-5045 - Needing help identifying component in AM/FM module
  • mikkele86
    • Apr 2017
    • 78
    • Danmark
    hello.
    I came across this thing and im not sure what it is exactly, I have never seen such thing before.
    I know it gotta be some kind of diode with Drain, Source and Gate1 and gate2
    It resides in AM/FM module and im measuring 200ohm across D and S.
  • mikkele86
    • Apr 2017
    • 78
    • Danmark
    and the back look ilke this
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      It's an old school JFET used to amplify weak signals in the receiver
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        Before all the rage of MOSFETs being used as switches, they were used as class C signal amplifiers, and this is a dual gate MOSFET.
        • mikkele86
          • Apr 2017
          • 78
          • Danmark
          ahh okay. many thanks
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            Google “dual gate jfet” or look at a BF981
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              Actually this particular device is a GasFet 2SK85.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                Eh... GaAs is fairly "recent" ... Is that a dual source or dual gate MOSFET? Depletion or enhancement?
                • m1ch43lzm
                  70mai Dash Cam A510 - help identifying connector on camera module
                  by m1ch43lzm
                  Hi everyone
                  I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                  The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                  I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                  05-11-2025, 06:02 PM
                • AlexVG
                  Replacing the WiFi module on a vacuum cleaner iROBOT i7
                  by AlexVG
                  I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                  I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                  (This board does not respond, only the LEDs light up in a circle.
                  The liquid damage is catastrophic and restoration is impractical).
                  (I bought this board to get the WiFi module and camera).
                  The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                  If...
                  10-22-2024, 07:20 AM
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
                  Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                  So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                  The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                  You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                  09-07-2024, 07:26 PM
                • DriversScrew
                  Omnitronic TUNA-NET Internet Radio - M1088 Module - any information or software?
                  by DriversScrew
                  I've got an Omnitronic TUNA-NET internet radio with an all in one module built around an esp32. The module must be a M1088 from ALD Ltd.
                  The device shows only a white display screen pulsing every second. Seems to have some kind of boot issue. All voltages and the pcb thermal signatures look good.
                  Any information about the M1088 module, schematics or firmware would be helpful....
                  10-04-2025, 04:33 PM
