Improving sound quality from computer
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Improving sound quality from computer
    You might hate me for saying this, but to me, this sounds terribly similar to "polishing a t*rd" And discounting the Mythbusters' achievements in this field, it just ain't gonna happen
    If i were you, i'd just pick up something like an older M-Audio sound card from fleabay or whatever - the Envy24HT-equipped ones had AKM converters, if memory serves, and quite highly regarded back in their day
    Or if you don't mind software-resampling in your music player (and provided you can find drivers), how about a Creative SB Live 24bit? I had one for several years, and i was real happy with it
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • lti
      • May 2011
      • 2547
      I think it is. However, I can't disable the onboard audio, this computer doesn't want to play any audio out of the sound card I have, and the speakers have a really low impedance that no other amp I have can handle.
      I have found a few things that I can change. The coupling caps on the outputs of the sound chip are only 0.1uF, and my calculations with a 10K ohm load give me exactly the same result I'm seeing directly from the output of the op-amp. Next, I can remove the caps in the feedback of the op-amps and increase the value of the caps in the feedback for the speaker amp to get the bass boost where I want it. It's more of a midrange boost now. Finally, there is another RC filter between the op-amp and the TDA1515BQ that causes the big dip at 300Hz. I'm going to find some of those surface mount caps and resistors to take care of that stuff.
      • lti
        • May 2011
        • 2547
        I can reduce the high frequency peak by putting a cap in parallel with the feedback network for the TDA1515BQ. It looks like a 2.2nF cap will be the best for that. I think I should try a cap in the feedback for the op-amp next.
        Also, putting a larger cap in place of the one that is already in the feedback for the TDA1515BQ reduces the low frequency peak, but the peak doesn't move like it did earlier. I don't know what happened.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Somehow, i'm not buying that What OS are you running on that computer? Even with Winamp you should be able to select what output device you're using.
          Low impedance, eh? And just how low might that be? Cobbling together an amp with a couple TDA20x0's or LM1875's shouldn't quite be "rocket science", if you're willing and able to change components on the mainboard
          Then again, there's more than a few "car audio" linear amplifier chips (some TDA____'s that i can't recall right now) that have two or four amplifiers in one chip, specifically made for single-supply (and/or bridged) operation
          • lti
            • May 2011
            • 2547
            I don't know the exact impedance of the speakers, but it's less than 4 ohms.
            The problem with this amp is the op-amp mess on its input and the low-frequency peak in the frequency response. If I connected a good audio source to the input of the amp, it would have a more normal frequency response. The high-frequency peak seems to be caused by something in between the amp and the op-amp circuit. There's nothing wrong with the audio output from the sound chip either since the headphone output sounds good (aside from needing bigger input coupling caps).
            • lti
              • May 2011
              • 2547
              Here is what I get after bypassing the op-amp mess. The amp is now connected directly to the sound chip output. I also added 0.047uF caps in parallel with the caps in the feedback circuit. There really was nothing wrong with the amp or audio chip (even though this is an ESS chip).
              Unfortunately, the output is quieter now. I might modify the op-amp circuit so it works as a simple amplifier instead of the pointless mess it currently is. Actually, it might be a tone control circuit to get the best sound quality from the Compaq/JBL monitor-mounted speakers. I think I also increased the value of those caps too much. There is a little midbass missing.
              • lti
                • May 2011
                • 2547
                This is what I get with only the left channel of the op-amp mess bypassed. I did this earlier yesterday to see what would happen before I posted last. I need to increase the gain to get the same output level I was getting before. Is there a way to calculate the gain from the output level in dB? It looks like I need 12dB gain, and I'm going to reuse half of the TL064 op-amp to increase the gain so the amp itself won't amplify the noise from inside the computer.
                • SeanB
                  • Jun 2013
                  • 41
                  • South Africa
                  #28
                  Feedback resistors need to be simple, no capacitors across them and typically about 47k between output and inverting input and between 4k7 to 10k to analogue ground ( not PC ground but likely a voltage of around 2.5V. Will give the desired gain and a reasonably flat response, you just have to remove the capacitors across the existing network ( not the 10uF to ground if present, it has no affect on frequency just removes the need for a Dc bias) to simplify it.
                  • lti
                    • May 2011
                    • 2547
                    This is going to be a simple inverting amplifier.
                    According to my calculations, I will need a gain of 4. Since the op-amp is a TL064 powered by a 78L09 regulator, the output will be clipped at high volumes, but the original mess clipped too. I found that out when Windows decided to play the startup sound at full volume.
                    How do I find the input impedance of the final circuit? The op-amp has infinite input impedance (ideally), but some other part of the circuit creates some input impedance. The sound chip is designed for a 10K ohm load on its output, and I don't want to go lower than that with this amp and the headphone amp.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #30
                      In an opamp circuit, the lower feedback resistor defines the input impedance. With an inverting amplifier circuit, that would be the one that goes between the source of the signal you want to amplify and the inverting input of the opamp.
                      A working TV? How boring!
                        Learn more here:
                        • lti
                          • May 2011
                          • 2547
                          All of the resistors in the headphone amp circuit are 10K ohm. I guess I need to change those to 20K ohm. For this preamp, I was going to use 20K ohm resistors in series with the inputs and 82K ohm feedback resistors for a gain of 4.1. It will be an inverting amplifier. If my calculations are correct, this will give a gain of 12.26dB.
                          • lti
                            • May 2011
                            • 2547
                            I haven't felt like messing with this yet, but I noticed that the output volume varies a lot more than it used to. Some sound files and songs are only slightly quieter than they were before, while others are so quiet that I have to have all the Windows volume controls turned all the way up. I didn't have to adjust the volume that much or that often before.
                            I did eventually find enough resistors for this. I've ended up with 61.9KΩ and 15KΩ resistors for the op-amp (if that amount of gain is even going to work with the wide variations in output volume) and 33KΩ resistors for the headphone amp. Those were just the values I had on junk boards (the 61.9KΩ resistors came from the original op-amp mess circuit - they're marked 77C).
                            • lti
                              • May 2011
                              • 2547
                              I finally made the preamp with the resistor values in my previous post. It works, but the output is still a little too quiet. The headphone output is slightly louder (with the headphones and speakers I have), but only by one step on my keyboard's volume control. That will be good enough for now.
                              It does sound a lot better than the original circuit, but I still need to find the right cap values for the bass boost. There is still some missing midbass, but that's a lot better than the Walmart mini-stereo frequency response I was getting before.
                              • eduaqa
                                Amplifier - bad sound when loud sound on bass
                                by eduaqa
                                I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                                I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                                08-06-2022, 11:28 AM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • Zonzi
                                Telefunken L70 speakers, one has a nasal sound with less bass
                                by Zonzi
                                Hi everyone !
                                Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
                                I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
                                They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
                                05-31-2023, 12:34 PM
                                RCA WHP141 wireless headphones wired up
                                by momaka
                                OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                02-22-2023, 06:28 PM
                              • LEECH666
                                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                by LEECH666
                                Good day ladies and gentleman!
                                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                01-19-2024, 05:46 PM
