Amplifier - bad sound when loud sound on bass
  • eduaqa
    • Jun 2022
    • 16
    • US
    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer
    The consumption is less than 500ma in both line (-23v +23v)
    I connected an oscilloscope on the audio out (together with the speaker), and I noticed that the voltage Peak-to-Peak on the speaker is less than 10V while working good (high volume not bass, or low volume with bass), but if I increase the bass and the volume the peak-to-peak on the speaker goes to around 20v-23v and the sound comes distorted.
    Any tip is welcome.
  • Ember
    • Aug 2022
    Re: Amplifier - bad sound when loud sound on bass
    It's a type of sound usually generated by increasing the gain of the signal. Distortion on your electric bass can be caused by your amplifier, wiring, cable, EQ, pedals, or audio interface. It can be done intentionally with pedals or unintentionally by many things.
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
    • UserXP
      Mackie CR4 amplifier no sound
      by UserXP
      Hi, people.
      I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
      Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
      10-17-2020, 05:06 PM
      RCA WHP141 wireless headphones wired up
      by momaka
      OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
      Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
      As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
      02-22-2023, 06:28 PM
    • JoelJ
      Ampeg PF-350 bass amplifier head repair
      by JoelJ
      Hello everyone!
      I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
      I have attached the schematic below.
      What I found:
      TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
      Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
      09-09-2025, 08:37 AM
    • Zonzi
      Telefunken L70 speakers, one has a nasal sound with less bass
      by Zonzi
      Hi everyone !
      Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
      I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
      They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
      05-31-2023, 12:34 PM
