Ceramic 3 Legged Resitor Source
  • Texas Blues
    • May 2010
    • 13
    Hi guys, dont post much here, but have found some very useful info in the past, and I thank you for that. Here lately, I have trying to find a source for this ceramic 3 legged resistor pictures below without much success. Its a 0.39ohm resistor that goes in the output circuit of a Realistic STA-2270 reciever. Found places that say they have th 0.33, or 0.47 versions, but not the 0.39. Any idea where to find this thing? The reciever is a 1985 model if that helps. Thanks for any advice. TB
  • midibob
    • Nov 2008
    • 285
    Re: Ceramic 3 Legged Resitor Source
    You may have already seen this thread but if not I hope it helps.
    http://www.electronicspoint.com/make...or-t62994.html
    Good luck
    Midibob
    • Texas Blues
      • May 2010
      • 13
      Thanks midibob, I did see that thread, and I have constructed a similar device. I have two 5W .39ohm ceramic two legged resistors that I have connected together. I just dont know if these 2 legged ceramics are suitable replacements. Or, if Im making my own out of two resistors, are the ceramics suitable or should I be using another type when connecting two together? The readings are good, and I dont see why this wont work, but thats what I dont know for sure. Thanks, TB
        Using two resistors with common legs in the middle is fine just have to be the same Watts rating since this for the Emitters of the output transistors, I use Flame proof resistors also if I run out of the ceramic body (which is also flame proof) for my old stereos from the 70's.
        I get most of these dual emitter resistors for repair from MCMELECTRONICS.
        http://electronics.mcmelectronics.co...E+DUAL+EMITTER
        • Lvsitano
          Asus X532FL 3.2V at source and gate
          by Lvsitano
          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
          First...
          06-26-2024, 02:13 PM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • LarrySabo
          Samsung ProBook NP767XCM-K1CA battery connector replacment source?
          by LarrySabo
          Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
          12-04-2024, 09:10 PM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • alltvrepairs
          Backlights required for Blaupunkt 50UN265 (HK50D08-ZC56AG-01) - cannot find a source
          by alltvrepairs
          I am unable to locate a set of LEDs for this model. Maybe you know a better source: 4 Strips of 8 Leds per strip.
          Tried with model or HK50D08-ZC56AG-01 but no luck so far.
          Regards
          07-06-2025, 08:29 AM
