MOSFET equivalent K8A60DA
  • tofik
    • Dec 2022
    • 26
    Hello guys,
    I have a shorted MOSFET K8A60DA with the following characteristics:
    Type Designator: TK8A60DA
    Marking Code: K8A60DA
    Type of Transistor: MOSFET
    Type of Control Channel: N -Channel
    Maximum Power Dissipation (Pd): 45 W
    Maximum Drain-Source Voltage |Vds|: 600 V
    Maximum Gate-Source Voltage |Vgs|: 30 V
    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
    Maximum Drain Current |Id|: 7.5 A
    Maximum Junction Temperature (Tj): 150 °C
    Total Gate Charge (Qg): 20 nC
    Rise Time (tr): 25 nS
    Drain-Source Capacitance (Cd): 100 pF
    Maximum Drain-Source On-State Resistance (Rds): 1 Ohm
    Package: TO220SIS
    Can I use the one from below as a replacement (in TV supply board)?
    12N65 MOSFET:
    Type Designator: 12N65
    Maximum Power Dissipation (Pd): 140 W
    Maximum Drain-Source Voltage |Vds|: 650 V
    Maximum Drain Current |Id|: 12 A
    Total Gate Charge (Qg): 58 nC
    Rise Time (tr): 28 nS
    Drain-Source Capacitance (Cd): 195 pF
    Maximum Drain-Source On-State Resistance (Rds): 0.7 Ohm
    Package: TO220AB
    or 10N65:
    Type Designator: 10N65
    Maximum Power Dissipation (Pd): 178 W
    Maximum Drain Current |Id|: 10 A
    Rise Time (tr): 69 nS
    Drain-Source Capacitance (Cd): 166 pF
    Maximum Drain-Source On-State Resistance (Rds): 0.72 Ohm
    Package: TO-263 TO-220 TO-262 TO-220F TO-220F1 TO-220F2
    or FQPF5N60C:
    Type Designator: FQPF5N60C
    Maximum Power Dissipation (Pd): 33 W
    Maximum Drain Current |Id|: 4.5 A
    Total Gate Charge (Qg): 15 nC
    Rise Time (tr): 42 nS
    Drain-Source Capacitance (Cd): 55 pF
    Maximum Drain-Source On-State Resistance (Rds): 2.5 Ohm
    Package: TO220F
    all datasheets available to download here:
    Code:
    https://drive.google.com/file/d/1DvokkcCS-DBOWRYAQPfgYVpYdiPWVd-j/view?usp=sharing
  • mon2
    • 16413
    Re: MOSFET equivalent K8A60DA
    The first 2 replacements are fine to use as they exceed the specs of the original. The last one, no.
      • 31823
      just make sure if the original was insulated from the heatsink the replacement is too.
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • tmaster21
        Ideapad 100 NM-A841, P channel mosfet on laptop in.
        by tmaster21
        Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
        Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
        07-17-2023, 09:48 AM
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
      • c_corr
        HP EliteBook 830 G7 blown low power mosfet unclear type
        by c_corr
        Trying to repair a HP 830 G7 board where I found the Q7001 a low power mosfet blown probably caused by supplying current to a shorted capacitor from the 5V line -> I plan to locate the shorted cap with the usual lab PSU set to 1V and limted to 2-3 amps and a thermal camera.
        Blown mosfet is shortcircuited and has a hole in its casing so I cannot read its marking properly hence my problem.
        Looking in the only schematic available everywhere on the internet the Q7001 shows as being a PJS6416-AU N-channel mosfet but the schyematoic image shows a P-channel mosfet and also there...
        06-21-2026, 04:33 AM
      • Tarot Superstars
        Reading N-Channel Mosfet Junctions (1N65)
        by Tarot Superstars
        Hi.
        I have a Mosfet in a power adaptor circuit and I want to know what is the Gate, Drain and Source.
        I have a data sheet and it shows which is the gate (#1) and I assume 2 and 3 are Drain and Source.
        But when I read it with a multimeter I read that it's likely not that.
        It seems to show that wire 3 is the gate and the other two are drain and source.
        I want to know because I want to design tests on the mosfet to see if it is broken.
        However, the gate of U1 (the pulse width modulator) is connected to wire 1 indicating it IS the gate...
        09-27-2023, 01:46 PM
