help finding a supplier with a specific lamp
  • vestaviascott
    Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
    by vestaviascott
    Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
    Here's what happens:
    1) Power on
    2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
    3) Blue status light flashes for appx 4 minutes...
    07-29-2020, 06:08 AM
  • AJ847.63e
    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
    by AJ847.63e
    Hi All.
    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
    09-18-2023, 06:42 PM
  • mikey5791
    Help on Samsung Syncmaster T220 dead ccfl lamp
    by mikey5791
    This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
    Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
    10-18-2020, 03:17 AM
  • khelane
    test active pfc power with lamp test
    by khelane
    Hello
    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
    Is there a way...
    06-03-2025, 01:00 AM
    HP Pavilion 15-cx0198tx Notebook 15 Specification for Upgrade or Repair
    This specification for the HP Pavilion 15-cx0198tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-cx0198tx boardview and 15-cx0198tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
    09-06-2024, 09:17 AM
