How to tell if speakers are blown
  • stevo1210
    • Oct 2006
    • 4156
    I've got a set of very, very expensive Bose Companion 5 computer speakers. Basically someone decided to turn the volume up all the way while the system was off (might be someone cleaning and accidentally turned the knob while cleaning). Anyway, I innocently went into itunes, and I nearly fell off my chair at the loudness of the music!
    I immediately turned them down to minimum. Then immediately got a torch and peered through the metal grille and I can't see any rips or the like in the tweeters or the woofer. I'm playing music as we speak and it seems to be playing okay, treble and bass is per usual. Nice smooth sound even at a higher range volume.
    These speakers are connected to the computer by USB, not the regular 3.5mm jack.
    Now what I want to know is... are they blown in any way? They are under warranty but I'd still like to know how I can detect a blown speaker.
  • stevo1210
    • Oct 2006
    • 4156
    Re: How to tell if speakers are blown
    Also found this in a manual from Bose for the Companion 5's...
    "The system output maybe reduced by an internal protection feature if you play music at full volume for a long period of time."
    Does that mean you can't blow the speakers?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      They've got a built-in compressor/limiter. You can still blow them up but you really have to try.
      Btw, Bose stuff nowadays is 99% marketing, 1% research. They are ridiculously overpriced for what's in there. Don't take them apart unless you want to have a heart attack.
      A working TV? How boring!
      • alan monro
        alan monro
        • Nov 2012
        • 9
        If the speakers sound OK they are OK , the ears are the final judge .
        All speakers are designed to take overloads for short times .
        You bugger them if they are overloaded for a long time or consistently...........................Alan
        • larrymoencurly
          • Oct 2004
          • 960
          A friend of mine had a Bose clock radio that blew its power transformer. I don't know if it has a thermal fuse inside or actually burned out windings, but it uses flat ribbon wire, a replacement was over $70 from some Ebay source, and Bose wouldn't reveal what the outputs were supposed to be.
          I think it's possible to damage a speaker from too much power without causing visible damage to the cone or suspension but just warp the voice coil so it scraps in the magnet gap.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            But then it would definitely sound bad, which seems not to be the case here, fortunately.
              master hoarder
              • May 2008
              • 12175
              I once forgot to turn down the volume in Windows after using it with my external speakers and the computer I did this with has a Yamaha YMF724 PCI sound card that has a TDA1517 amp IC (capable of 6W/channel). I don't know if my Sony MDR-023 headphones took any damage, but my ear drums sure did! I kid you not, I nearly fell off my chair. Those headphones still work fine to this day and I still use them regularly.
              I've also seen many YouTube videos where people try to blow speakers up. Most will take quite a while before they go out (granted it's not one of those let's plug some speakers in the wall socket and see what happens videos).
              • lti
                • May 2011
                • 2548
                The amplifier in my Cyber Acoustics MMS-20 speakers can blow speakers easily. It only uses a TEA2025B amplifier, but the bass boost is too much for my $10 Philips headphones. Those headphones sound like larger and more expensive headphones when they are connected to that amp... until they start buzzing.
                For some reason, that amp only boosts the bass on one channel if the coupling caps between the tone control circuit and the TEA2025B aren't perfectly matched. It is hard to hear the difference in headphones, but it is easy to tell the difference through the speakers.
                Speakers won't blow after only a few seconds unless the amplifier is rated for many times more power than the speakers.
                  Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                  by momaka
                  More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                  02-15-2022, 12:43 AM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • Widget
                  Logitech R20 speakers - Replacing one of the speakers.
                  by Widget
                  Hi guys,
                  I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                  Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                  Printed on the back of the Logitech speaker is;
                  LOGITECH...
                  05-29-2024, 07:07 AM
                • ageman
                  Bose wave music system lll
                  by ageman
                  Hi all.
                  I have a Bose wave music system lll.
                  This issue is when I power on I get the normal please wait the cd will make a noise, pulling the cd in and out several times then I get disc error and display goes blank. Does the same with no disc. I have no schematics so unsure if I am not getting voltage to cd.
                  TIA
                  Adrian
                  09-05-2021, 10:30 AM
                  Acoustic Audio GX-400 speakers
                  by momaka
                  Part 1 - Acoustic Audio GX-400 build "quality"
                  Not going to lie – this will be another silly audio post/thread. If you thought the cheap Panasonic Thrusters speakers I posted about last time were bad enough, then you are about to explore some new depths in lo-fi audio here. Ladies and gentlemen, I present you the Acoustic Audio GX-400 speakers... or speaker (only pictured one for better details )
                  Before I continue any further, perhaps you might be asking why I even bother to post about such crap audio gear (let alone keep it). The answer...
                  03-07-2019, 09:04 PM
