Are these Jamicon caps OK! Do they have a decent reputation? I ordered some 6800uf, 63volt,105c caps from WES components and this is what they sent me,I'm going to put them into a Sherwood RD6405 surround sound 5.1 amplifier 125wpc.What do you think?
Jamicon capacitors any good?
HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Tags: None -
Re: Jamicon capacitors any good?
Fine for general purpose uses. Audiophiles may have a fit though.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Actually I was putting feelers out for people who have used them more than anything. I have read the data sheet but it doesn't say what they sound like? As for audiophiles,they can have a fit because a lot of the time they don't know what they are talking about because they are preyed upon by unscrupulous manufactures and dealers of pseudoscience,which they take to be fact. Anyway that's my take on it,coming from nearly 50 years of building and repairing Amplifiers and general consumer electronics.HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
I seem to have some faith in Jamicon units.
With the units from WES, I cross-referenced Jamicon WL (3000H) with Chemi-Con LXV, Jamicon TK (2000H) with Chemi-Con KMQ (radial), Jamicon HSW (2000H) with Chemi-Con KMH and Hitano EXR (2000H) with Chemi-Con SXE.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
OK that's good enough for me Japlytic coz after all its the user of these products that has the last say in the matter and the most important,I'm sure if there was just a hint of badness about them I would have heard by now.Cheers.HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
They don't take heat too well... Ive seen quite a few roasted in bestec PSUs (granted, other desing faults were involved).sigpic
(Insert witty quote here)Comment
I fished quite a few bad ones out of DJ CD-players (those rackmount double deck ones) with linear PSUs.
Four Jamicon 25V 2200uF IIRC. Issues were that the player had a mind on its own.. Like randomly stopping playback (or not finding tracks), pitch control going bonkers or not "starting up" properly (turned on with a blank LCD and didn't respond).
Those caps had basically no capacitance left. And the player wasn't exactly hot-running.
What was the temp spec on the failed Jamicons, 85c or 105c or both?HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
