Transformer Hum...
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Transformer Hum...
    Hi, I bought a new receiver a few months ago because the 30 year old Sony was starting to show it's age...
    I did not need anything fancy so I went with the cheapest with the most features I could find... It's only driving 2x speakers of unknown wattage...
    Anyway, it's a "Centrum Titan 500" also known as "Eltax AVR-800" I'm using both Optical input and analog from my computer... With both of them I can hear a humming sound best decribed as the sound you hear standing outside a really big stepdown transformer station... Anyway could this be filtered somehow? Some magic gizmo to put on the transformers cables perhaps?
    EDIT; The receiver is on a true sine wave UPS that delivers 230.0v 24/7/365, the hum is coming from the speakers, it disapperars if I tune the volume down to 0, but is as audiable at sound level 1 as on 15...
  • Tom41
    • Oct 2005
    • 336
    • England
    Re: Transformer Hum...
    Sounds like turning the volume down to 0 actually cuts power to the amplifier. Some amps (mainly those with digital volume controls) are like this, others just mute the sound going into the amp (typically with analog volume controls).
    If the amp were still on, you'd hear the hum.
    Since the hum is audible both at minimum volume and at maximum volume, I'd say the problem lies within the amplifier circuitry itself. It may not even be a mains hum, it could well be interference caused by the transformer coils being too close to signal wires. Does the hum still occur if you disconnect your computer from the input? Have you tried another input device? (guitar, microphone, tape deck etc.)
    You know there's something wrong when you open your PC and it has vented Rubycons...
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      this is the key, if you get the hum with only optical connected then it is internal
      • arneson
        • Sep 2005
        • 1267
        Is the power plug a two wire or grounded three wire.
        In other words, can you reverse the power cord?
        Jim
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          disconnect all inputs and test.
          if it still hums its an amp problem.if not it could be a ground loop.
          maybe it simply forgot the words.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Ok, I disconnected the Optical and Analog cable and then there was no hum at all, but the hum is the same with either the analog or the optical cable only connected... The analog goes to my computer and the optical to my satellite receiver...
            The equipment is properly gounded, however the only equipment in this discussion that actually is grounded is the the computer, because all the other gadgets come with only the usual two lead wires... No ground...
            There was no difference heard by reversing the power cable to the receiver...
            There is also no hum if I switch to the inputs not in use, like Coaxial or Optical-2
            • arneson
              • Sep 2005
              • 1267
              My AV receiver was doing this also and I found that the inputs were on a small daughter board plugged into the main board.
              When I pulled the board and reseated it the hum was fixed, still works perfect now.
              Jim
              • stretch0069
                Screwed Up Super Moderator
                • Oct 2003
                • 2658
                • oooo ess aaaaaaaaa
                had this problem with an old McIntosh amp. If I remember correctly, my roomie ran a 12ga wire from the amp chassis to the ground inside the the wall outlet. No more hum.
                "Its all about the boom....."
                Guns kill people like spoons made Rosie O'Donnell fat.
                We now return you to your regularly scheduled drinking.
                "Fear accompanies the possibility of death.....calm shepherds its certainty"
                Originally posted by Topcat
                AWD is just training wheels for RWD.
                • arneson
                  • Sep 2005
                  • 1267
                  I've recently found that sat receivers are often the cause of ground loop problem.
                  Had two units out of three with AC on the cables. They were wipeing out boards on the tracking device.
                  Jim
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    if the amp mutes on loss of input that may complicate things.
                    time to go poking around inside with a scope.
                    btw is it 60 or 120 hz hum?
                    60=something on amp input.
                    120=bad filter caps.since every one i have seen used a full wave bridge in the psu.
                    • brbpab94
                      • Mar 2007
                      • 22
                      can't you sheild it.between the transformer and the signal wires.
                      • JRade
                        Audio video receiver KENWood KR-V990D,no sound
                        by JRade
                        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                        I replaced the capacitor C303/0.047F, nothing changes.
                        I'm asking for help, what should I do next?
                        Thanks in advance!...
                        08-05-2025, 10:23 PM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • karthur
                        Vizio D65x-G4 Volume changes on its own
                        by karthur
                        On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                        It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                        06-05-2025, 08:13 AM
                      • jorpec
                        Loewe opta R125 distorted sound at high volume
                        by jorpec
                        Hi
                        I'm restoring this vintage radio, that had a very weak sound output, after replacing the electrolytic capacitors the sound volume improved but when the volume reach the middle of the knob starts to distort, its like the speaker overdrive and saturates, but only at lower frequencies even with the tone knob at minimum on bass frequencies. i have tried with other speakers but is the same.
                        Any idea what causes this ?
                        Below the schematic
                        Thanks...
                        03-02-2022, 11:51 AM
                        RCA WHP141 wireless headphones wired up
                        by momaka
                        OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                        Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                        As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                        02-22-2023, 06:28 PM
