Well here we go. A blast from the past hehe. A good friend of mine paid a ton of money on ebay for this dang thing. It was taken to another repairman becuse of some issues and when he got it back, not only did it still have issues, now it has a bad fugly toggle switch on it lol..
so i get it, heres the issues:
- left channel quieter than the right.
- left channel pops and cuts out, comes back
- left channel sometimes cuts out, comes back popping like a machine gun
- tape a does not work, bad belt.
- power switch hacked in
- broken antenna.
I go ahwad and tear it apart. THeres cold solder all over this thing, worst at the audio amp ics. I then notice the heat sink on the left channel amp is is loose. So i tightened it. Now the heatsink gets BLAZING HOT almost immeadiately. I get to looking some more, the left external speaker jack is broken and has a intermittent short..
SO i think what happened is the ic was alteady struggling with basically no heat sink and cold solder, add the shorting speaker jack, its a wonder this thing works at all.
The ic is a toshiba ta7270p. I plan on just replacing both ics to make sure theyre fresh. I will reflow any other questionable solder, and remove that shorted out external speaker jack.
Ive found the ics and replacement whip antenna on ebay so im set there, which leaves this power switch. He hates it, and i dont blame him.
Does anybody know or anyone with lasonic boombox parts?
Anybody know where i can buy replacement tape deck drive belts here in the states?
Heres a pic of the beast.
- broken antenna.
