Yamaha RX-A3010 left channel no signal
  • HelpMeRepair
    • Jun 2022
    • 62
    Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
    what I did so far ,
    factory reset
    test all other channel
    tone test
    dissasemble and look , visual inspection witout full dissasembly
    looked at all the mosfet for temperature to see if they eas operating
    scratch my head couple of time
    thanks in advance all help is appreciated , service manual are welcome too ! =)
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    I would go after easy low fruit first and resolder everything that has a heatsink on it (like anything on a heatsink).
    Try messing around with different input and output settings to see if there is some setting where the channel actually does work?
    There is no DC on the output, because the amp should be in protect mode then.
    • HelpMeRepair
      • Jun 2022
      • 62
      all right I'll disassemble the unit and proceed to resolder everything that is connected to a heatsink ! thanks you good sir
      • HelpMeRepair
        • Jun 2022
        • 62
        Av receiver is fixed ! found that the front left channel joint was completely cracked , full disassembly of the back all the audio board side and visual inspection made it ! thanks for the help I'll keep the SM , and if there any real good tilps on saving the DTS IC , i was thinking about installing a fan to keep it cool , maybe combine it wit a heatsink , but if someone have tryed something and has no problem wit it for many yeara working that way , let me know please ( except glueing a heatsink to the IC )
        I think that keeping the equalizer on the low side ( -3db ish ) and not cranking it past 75-80% for long run could be a good idea but im no expert in this , and either about those IC knowledge Click image for larger version
ID:	3508871 Click image for larger version
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          You got her going again! Awesome!
          • HelpMeRepair
            • Jun 2022
            • 62
            yes ! sounds great too, thx for the help
            • xfreakx
              Yamaha XP7000 Crackling in left channel
              by xfreakx
              Hi guys,
              I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
              The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
              While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
              I switched the mono blocks for a test to make sure the error is in the block itself...
              06-29-2023, 05:30 AM
            • CDNBrewer
              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
              by CDNBrewer
              Hello Everyone,
              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
              Symptoms:
              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
              • I swapped the Left and Right surround
              08-05-2025, 09:29 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • Sik_6ty_Sixx
              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
              by Sik_6ty_Sixx
              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
              02-18-2025, 05:06 AM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
