Homebrew FM Radio antenna
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I finally am getting around to posting this..
    what happend was i bought a magnavox mini system for $15 at a thrift store. it was that cheap because it was coved in spongebob stickers (easy fix), and missing the remote and antennae. i also found a different brand antenna to fix that problem or so i thought...
    turns out dipshit over here was hooking an AM loop to the FM connection :faceplam: i always wondered why my reception was so bad... until an off topic physics discusioon this spring lit a bulb in my head...
    what went wrong was the AM connection used a pwer supply fan type connector and the FM used bare Lead connections. the AM loop had bare leads. easy fix... snipped a lead off off a dead fan from a gutless psu and soldered and taped it.
    which left me w/o an FM antenna. i decided i would make it homebrew... first, i decided to make each wire coil around an insulative frame, coing away from each other. for a frame, i found that a plastic pants hanger fit the bill... it had a place to tie wire off and a way to keep the the coils separate. as an added bonus, the hook ansd clims made it so i could either hang it or clip it to a shelf.
    it was made and has worked well... i get a very strong signal in my basement, which iirc is a low signal area.
    a pic of it:
    any comments/ suggestions?
    sigpic
    (Insert witty quote here)
  • Radio Fox
    • Jan 2010
    • 281
    Re: Homebrew FM Radio antenna
    You would probably get better reception if you slung up a dipole antenna of the correct length. You have too much wire on that hanger for FM reception.
    Idealy the impedance of the antenna should be 300 Ohms. You could construct an antenna using 300 Ohm ribbon cable of the correct length, or it may be cheaper to buy a ready-made one.
    The next best thing is to construct a half wave dipole out of something you may already have to hand, such as speaker wire or twin mains flex, where the 2 wires can be pulled aprt & seperated into a "T" shape.. The total length of a half wave dipole is 468/f(MHz), which, for the centre of FM band II is 4 feet 9 inches.
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
      • 31305
      you want to get the antenna up in the loft,
      height will help more than design.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        it is a finished room, nowhere to hang it.
        it is working fine so i am leaving it as is.
        i have yet to see premade antennas anywhere...
        sigpic
        • delaware74b
          • Apr 2009
          • 628
          Ratshack has one if you're willing to part with $7.
          Here's the link: http://www.radioshack.com/product/in...ductId=2062691
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • PlainBill
            • Feb 2009
            • 7034
            #1 rule of engineering. If it works, you did something right. On the other hand, a lot of these just use a length of wire - 30" IIRC.
            PlainBill
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              it is speaker wire... they do split in a T... do some math, i think my wire lengths are close to ideal... it is just a compact version.
              sigpic
              • cadiman
                • Mar 2010
                • 397
                fm is 32" and am should be around 48" Think automotive
                • romansroad
                  • 123
                  I like this build! It's compact and will keep your tee-shirts off the floor as well. MI-6 no doubt will be interested
                  I've studied/built countless am loops and high gain directional fm loops. The ARRL handbook has some great designs, and you can tune them to your desired freq range. I prefer the multi-element loops, but they are by their design, directional.
                  Agreed that altitude is your friend, but if you have no access, that limits it some. If you wall access, you can slip up a wire in that space along the outside wall, and you'd be surprised how well it works. Keep in mind that there may be 110v lurking in there, so safety first and you may get some 60 cycle hum.
                  I recall that C. Crane company had a decent selection of pre-made antennas (but what's the fun in that!?) so take a look there. Overall, Plain Bill is right (no surprise!) and it looks like you've done it right if its working. I've found FM to be a bit capricious at best, and even my superior designs (IMHO) could get trumped by a dipole some days! Go figure....
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • UserXP
                    Vintage SONY Digital Clock Radio ICF-C12W no audio
                    by UserXP
                    Dear all,
                    I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                    i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                    My question is, do you know of this brand of capacitors and how bad are...
                    07-21-2025, 08:35 AM
                  • praveenramavath
                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                    by praveenramavath
                    Hello All,
                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                    https://www.hifivision.com/threads/m...-screen.98243/
                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                    04-26-2025, 09:08 AM
                  • BOSCHNJAK
                    by BOSCHNJAK
                    ABOUT ME INTRODUCTION FILE
                    2
                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                    2022 BEV, PROJECT ?
                    2021 BEV, PROJECT ?
                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                    12-28-2023, 02:09 PM
                  • Hondaman
                    Single-channel antenna?
                    by Hondaman
                    Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
                    I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
                    Years ago I made a "T"...
                    11-18-2024, 01:14 AM
