Marantz SR5008 Protect Mode
  • mmartell
    • Oct 2013
    • 3189
    If I restart in Diagnostic Mode the error is ThermalProtB.
    If I start in Protect Bypass mode the unit runs flawless until next power up then will go back into Thermal Protect since the anomaly has not been corrected.
    If I measure the Thermal Detect B line coming from the Amp it measures identical to the Thermal Detect A line (about 1v). This makes me think the problem is not in the amp but in the way the B detect is handled.
    I can't tell if the cpu is looking for active low or active high to shut the unit down. I'm attaching the SM, schematics and a screenie of the pin designations of the cpu.
    Any pointers definitely appreciated here.
  • R_J
    • Jun 2012
    • 9535
    Re: Marantz SR5008 Protect Mode
    1 volt does seem a bit odd, most of the detection appear to be supplied by the SWM3.3V
    maybe a fault on the cpu level change board, page 24 of schematic?
    • mmartell
      • Oct 2013
      • 3189
      Don't think so. The output of transistor Q3615 (D.Supply pg.27) which creates SWM3.3V reads 3.3v from power on until the unit kicks off into protection.
      • R_J
        • Jun 2012
        • 9535
        Have you checked the TR_THERMAL line and the RADI_THERMAL lines coming from the amp board (page 25), I would expect that they would be the same voltage, the amp board uses 5 volts for the error transistors
        The TR_THERMAL line changes into THERMALDETB line. It then goes to the cpu level change board and gets convertd to 3.3 volt logic. THER_PROTB, so maybe a fault with Q3212, or the digital transistors Q3213 or Q3215.
        Then it uses a resister ladder circuit to tell the cpu which error is on the THERMALB_DC_ASC line, that would explain why its around 1 volt I guess.
        Looks like THER_PROTB line would drop the 3.3 volts the most so I would think the THERMALB_DC_ASC line should be close to 3.3 volts withoutany error.
        • mmartell
          • Oct 2013
          • 3189
          I think I misunderstood you. Yes the fault should either be one of those two circuits on page 24 or one of the four channels monitored by the detection circuit on the Amp board, pages ten and eleven.
          How to proceed knowing this ?
          Last edited by mmartell; 03-02-2019, 09:31 PM. Reason: Posted while you were posting...
          • mmartell
            • Oct 2013
            • 3189
            Those are the lines in no-mans land, around 1v.
            • mmartell
              • Oct 2013
              • 3189
              Right so the cpu is testing the voltage on that pin to discern which fault it has. I was wondering about that...
              • R_J
                • Jun 2012
                • 9535
                Have you compared the THERMALB_DC_ASO line with the THERMAL_H/P_MIC line
                I would guess if the THERMALB_DC_ASO line was about 2.5 volts, the error would be DC_PROT, or 2.0 volts, error would be ASC_PROT
                • mmartell
                  • Oct 2013
                  • 3189
                  I can't measure the circuits on page 24 when powered because the flex cable from the front panel covers that. I can run a jumper giving the cpu 3.3v and see if that allows the unit to power on without error.
                  But how can I tell if those circuits are actually functioning properly and the problem is on the amp board ?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Originally posted by R_J
                    Have you compaired the THERMALB_DC_ASC line with the THERMAL_H/P_MIC line
                    Yes. Those lines read the same. I have the pin pulled from the connector at the moment as I was considering jumping the relevant cpu pin to 3.3v
                    • mmartell
                      • Oct 2013
                      • 3189
                      There doesn't seem to be any documentation on the levels of detect but this is from the SR7008. I don't know what it's saying but maybe it's relevant to SRx008 series ?
                      • R_J
                        • Jun 2012
                        • 9535
                        I would think that with out any error transistors turned on there should be 3.3 volts supplied to the cpu via the pullup R3227, the same with the THER_PROTA line, It should be 3.3v via the pullup R3251
                        The CPU is looking an analog input on pin 133 so its not a high or low (0 or 3.3v)
                        cpu pin 133 or 134: A/D converter AN0 to AN15 Input pins for the analog signals to be processed by the A/D converter
                        • mmartell
                          • Oct 2013
                          • 3189
                          Thanks for that explanation. That makes sense.
                          • mmartell
                            • Oct 2013
                            • 3189
                            ...so maybe a fault with Q3212, or the digital transistors Q3213 or Q3215.
                            Should removing Q3215 simulate a no fault condition ?
                            • R_J
                              • Jun 2012
                              • 9535
                              It should, that's if the fault was caused on the THERMALDETB line
                              • mmartell
                                • Oct 2013
                                • 3189
                                That's what worries me but I'm hoping it's one of those three transistors. Will remove it and see what happens.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I have not yet removed this transistor because the logic doesn't seem quite right, or maybe I'm over thinking it.
                                  This troubleshooting flowchart from the SM indicates an error condition presents with a +0.6v or -0.6v on one of the detection pins. I measure 0.7v on both thermal pins when the unit is trying to start up before it goes into protection. At that point the voltage returns to zero when the led flashes red as it says. Isn't that to be expected ? Shouldn't I see the error voltage when the unit is trying to start ?
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    I never did like flow charts, especially chinglish. It seems to say if you get +- .7 volts that is good, if its 0 there is a problem. Its obvious if the amp shuts down the voltage would go to 0
                                    What about pulling CP4001? That should eliminate any error signal coming from the amp board.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      I read it that +/- 0.6v is amp damage (DETECTION circuits detecting something) and 0v means the PROTECTION circuits or cpu itself have a problem.
                                      Either way I cannot find a CP4001 so I'm not sure which connector they're referencing. I think it's just a means to let the unit power up without shutting down to check what faults were registered.
                                      Question: Should the amp error detection circuits work unplugged from the rest of the circuit (the protection circuits) ? If that's the case and the amp is NOT the problem unplugging connector C404 should allow the unit to boot up fully but it still goes into protection.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        By the way I measured 0.3v at R3227 (leads directly to cpu pin THERMALB_DC_ASO) during boot before protect kicks in.
                                        • BigOof
                                          Marantz SR5007 popping on volume change and mute in Direct Mode
                                          by BigOof
                                          I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                          12-12-2024, 06:15 AM
                                        • DynaxSC
                                          Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                                          by DynaxSC
                                          I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                                          I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                                          Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                                          Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                                          05-04-2025, 12:08 PM
                                        • x16
                                          Lenovo Thinkpad T14 gen 1: Unlock MEC: in protect mode
                                          by x16
                                          i have Lenovo Thinkpad T14 gen 1 20S1 / SN: PF2M0XAG.
                                          I moved resistor like every time and read MEC chip with SVOD4. I unlocked 3 other mainboards successfully but this one could not read. SVOD 4 Software says: "MECxxxx series in protect mode, work mass erase only". Like in screenshot.
                                          What can i do?...
                                          11-14-2024, 01:31 PM
                                        • cook
                                          HP Power Supply 6632A: Fast Mode vs Normal Mode?
                                          by cook
                                          FAST MODE vs NORMAL MODE
                                          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                                          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                                          06-07-2020, 05:32 AM
                                          Acer Spin Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver Hybrid (2-in-1) 1 Specification for Upgrade or Repair
                                          This specification for the Acer Spin Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver boardview and Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver schematic. Our users have...
                                          09-07-2024, 01:00 AM
