Microwave issue NN-C897WBBP
  • llonen
    • Sep 2014
    • 495
    • hampshire
    I don't usually have these in for repair since they are generally so cheap no one wants them repaired, anyways so this Panasonic (NN-C897WBBP) comes across my bench. Its a dual oven with microwave and fan conventional oven, when in microwave mode it will run for a random length of time before shutting itself down and immediately restarting, usually around a minute maybe a little longer.
    On inspection as suspected the magnatron cooling fins and fan assembly were caked in grease and muck, a thorough cleaning and inspection of the thermal trip and micro-switches revealed nothing of significance. Reassembly and testing revealed the same behaviour, removing the HV supply to the magnatron showed up the same behaviour. Clamping the supply in showed about when I would expect for a current draw for this appliance. When it does remain on long enough it will boil a mug of water within two minutes.
    thoughts please.
    • 31250
    Re: Microwave issue
    check the pcb for bad caps or soldering.
    • llonen
      • Sep 2014
      • 495
      • hampshire
      Re: Microwave issue
      I had a look at the main controller board, what few caps there are on there appear in good condition, there are a number of flat film connectors going out to the display and touch panel which I am not inclined to interfere with due to age. There is no problem with the convection part of the oven which seems to function well enough and that is what the client has been using for a while.
      • R_J
        • 9607
        Re: Microwave issue
        without pictures its hard to tell but are there any relays on the control board? if there are, resolder there connections.
        When the mwo shuts down do you loose the display?
        Monitor the voltage on the primary of the magnitron power transformer and see if you loose the voltage
        • llonen
          • Sep 2014
          • 495
          • hampshire
          Re: Microwave issue
          I can get some pictures tomorrow, I am reluctant to disturb the main controller board since these flat film connectors are old and potentially brittle. There is a sub assembly with a a number of relays which I will be removing and testing for next step. when the MWO stops it looses display then immediately restarts asking for clock settings the primary of the magnitron power transformer drops from local supply (230-240) to zero and stays there although can be resumed by setting an appropriate power / time and restarting. from here it will run for another 1-2 minutes.
          • R_J
            • 9607
            Re: Microwave issue
            If the display is dropping out and the clock needs to be reset, you must be loosing the main a/c in somewhere.
            I would check the connections and any thermal cutouts in the line from the cord to the control board. It could be as simple as bad connections on the low voltage transformer for the controller
            I could not find a service manual for this model
              • Jul 2011
              • 6070
              Re: Microwave issue
              Check your main power lines inside the microwave oven for bad connection and look very closely at connection that are crimped have seen this before
              • llonen
                • Sep 2014
                • 495
                • hampshire
                Re: Microwave issue
                Update and I am leaning towards a microprocessor clock controller fault of some kind.
                Customer said shutdowns were random, they are not it shuts down precisely at time elapse 59 seconds as it rolls over. Additionally the shutdown occurs irrespective of microwave, oven, grill or combination there of.
                Power-lines have been rechecked, filter board checked and re-flowed not that there were any obvious bad joints. Thermal trip function verified and removed, current monitored, on monitoring the voltage rails I don't see any interrupt of supply to the controller board
                  • Jul 2011
                  • 6070
                  Re: Microwave issue
                  Ok here is what I would do if I were troubleshooting this microwave oven and you think it the controller board
                  First question dose it have a small power supply transformer on this board check the diodes right next to the transformer and make sure that they are good or does this unit have a switching power supply if it does there should be a switching power supply regulator IC chip on the board it might have any where from 4 to 8 pins on it and in a 220 ic chip case or a dip ic chip or a surface mount ic chip
                  I would need the part number of that IC chip if it has one
                  I would recommend powering it from the controller board where the main power leads hook up to it with nothing else hooked to it and see if it still does the same exact thing
                  • R_J
                    • 9607
                    Re: Microwave issue
                    If you program 5:00 min, does it count down ok and reset when it reaches 0:59 or does it reset at 4:59, If you program 0:50 does it count down ok?
                    I suspect the microprocessor has an issue, I seem to remember something similar with the panasonic mwo's. Its been awhile
                    • llonen
                      • Sep 2014
                      • 495
                      • hampshire
                      Re: Microwave issue
                      The control board is powered by a conventional linear psu since the reset / shutdown is highly predictable and not what the client described I feel it is unlikely the problem to be supply related. That said I will look into separately powering the controller board, I do find that setting 50 seconds it will complete the time but anything over 1 minute results in a restart / reset.
                      • llonen
                        • Sep 2014
                        • 495
                        • hampshire
                        Re: Microwave issue
                        So powering the control board from a separate supply made no difference, unless anyone has any further thoughts on this I am going to inform the client that this is a controller issue and since I am unable to obtain replacement unit that this one is not going to be repairable.
                          • Jul 2011
                          • 6070
                          Re: Microwave issue
                          This is best thing to do because if you power it separately from the microwave and you still have the same problem then I would have to agree with you that it has some type controller issues and not worth fixing it
                          • valvashon
                            Toshiba EM131A5C-BS microwave oven- noisy EE16 2.7 mH inductor
                            by valvashon
                            This poor microwave oven was purchased by my former employer in 2019 (it's a 7/2018 build) and lasted for about 3 months before making a terrible noise when in use. I determined that it was the main transformer and contacted Toshiba. They asked for a picture of the cord cut in half and the serial number, and then credited my boss' credit card. Rather than sending it to the e-waste, I bought a transformer on eBay and thought I'd try flipping it. Discovered that used microwave ovens aren't worth much but in for a penny, in for a pound as they say. It sat in my basement getting kicked and shoved...
                            02-20-2024, 10:38 AM
                          • tbsmith
                            Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
                            by tbsmith
                            I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
                            07-12-2025, 11:40 AM
                          • Use2bavolvo
                            Magic chef oven - thermistor ref voltage issue
                            by Use2bavolvo
                            I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                            Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                            01-19-2023, 01:32 AM
                          • goodpsusearch
                            Daewoo microwave oven repair
                            by goodpsusearch
                            One day my microwave oven stopped heating.
                            It would turn on and rotate the plate but no heat.
                            I removed the cover and checked components with digital multimeter.
                            Found that the high voltage fuse was blown.
                            This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                            Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                            I replaced fuse and tried to heat up a glass of water.
                            Strange noise...
                            01-24-2021, 03:56 PM
                          • tmhobadcap
                            Can a microwave oven be used to reflow solder joint?
                            by tmhobadcap
                            I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
                            Is that possible? I do not want to try this unless I have a spare microwave oven.
                            (I do not mean to suggest somebody to try this. It may be...
                            10-30-2020, 08:38 PM
