Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
  • tbsmith
    • Sep 2016
    • 22
    I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side. Since some buttons work (with the 2.5V) at the same time as the others that don't indicates to me that the power supply is okay. Leaving it unplugged overnight sometimes helps, but not always. All solder joints seem to be good under magnification. I'm thinking there might be a bug in the firmware or a problem with the microprocessor due to the random nature. Does that sound like a possibility? I purchased an FTDI USB adapter hoping that I can check the firmware, but having never used one before. Is that something one can learn fairly easy, or is there a steep learning curve? The micro is an STM 32 ARM Cortex.
    I couldn't find any youtube videos on repairing this model and no luck finding a schematic either.
    Click image for larger version  Name:	Ninja DCT 410.png Views:	0 Size:	247.2 KB ID:	3680873
  • CapLeaker
    Leaking Member
    • 8340
    I am betting that the firmware on the STM32 is locked. Only thing you can do is to swap in a new board. I haven’t gotten a device with an STM32 that wasn’t locked. Look around on Ali… maybe you find a board for cheap.
    • tbsmith
      • Sep 2016
      • 22
      I didn't find any control boards on Ali, but saved a search on eBay, something may come up. Thanks so much for sharing your experience with STM32's; that saved me a bunch of time trying to learn how to program or even access it! Worst case is that I will strip it for parts.
      • CapLeaker
        Leaking Member
        • 8340
        Maybe call the manufacturer Ninja and ask them for a replacement board?
        • lotas
          • Jan 2016
          • 4797
          • Russia
          First, check the processor power supply for pulsation (or replace the electrolytic capacitors in the power supply), regarding the buttons, membrane buttons can "leak", that is, have a leak between the membrane and the contact pad and create internal resistance and a false triggering occurs, while no button will work (this does not look like a firmware failure).
          • tbsmith
            • Sep 2016
            • 22
            Thanks for the suggestions. The power supply was good. The push buttons are discrete surface mount and all tested good. After letting it sit on the bench for a few days, the behavior changed to where only the rotary encoder would power it on (but not in the way it is supposed to). Anyway, this convinced me that it is unrepairable so I stripped it for usable parts and trashed the rest.
            Thanks to all for your help!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              I 2nd what lotas mentioned in regards to the buttons - sometimes they start to partially short over time, and the symptoms could be completely intermittent too. I've had a few monitors suffer due to this and randomly pop up menus or change their brightness and etc. In some cases, it's temperature-dependent and nothing happens until the monitor heats up. Nearly pulled out all my hair with a 24" Dell some many years ago due to this. Just because the buttons appear to read OK when checked once with a multimeter does not mean they are OK. The best but probably most painful way to deal with this is to run some external wires from the buttons and have at least a few multimeters checking the voltage going to them. Or alternatively, remove the buttons and have external wires that you can manually connect... though DO be CAREFUL with that, as some cheap appliances do not use isolated power supplies and can be a HAZARD to work on without a ground isolation transformer.
              Anyways, I know it's probably a moot point already mentioning this, now that you scrapped it. But just in case anyone else ever stumbles onto this.
              • tbsmith
                • Sep 2016
                • 22
                Thanks for the new info. I had the exact issue with one of my HP monitors. I had to remove the pcb containing several pushbuttons that controlled the menus. It wasn't a problem since I never have to change the settings. But based on the behavior of the air fryer, I'm not sure that was the issue. Too bad I scrapped it, or I would have done more testing. I would have just removed all the pushbuttons and used a jumper wire to test. Oh well. The other weird thing is that two previous units that were replaced under warranty had the exact same problem, but I don't see any others posting about it.
                • KYBOSH
                  Trying to revive a NINJA OL501Foodi 14-in-1, 6.5-QT Pressure Cooker Steam Fryer with SmartLid
                  by KYBOSH
                  Found another appliance to experiment on.
                  https://support.ninjakitchen.com/hc/...4-OL500-Series
                  Previous owner complained that it would power on but the heating element, located in the lid, would not heat up. Customer support told them there is no replacement parts for it.
                  Will try to figure out what's what shortly.
                  Anything i should keep an eye out for?...
                  08-26-2024, 04:30 PM
                • Fsufan1391
                  LG Oven model LREL6325F
                  by Fsufan1391
                  Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                  04-23-2025, 05:42 AM
                • schnauzer2021
                  Chasis bond to neutral to overcome oven tripping problem
                  by schnauzer2021
                  I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
                  Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
                  I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
                  As I was too busy with my work, I leave it to the repairman...
                  09-13-2021, 02:40 AM
                • bpjl
                  SEF 551.10 - Error starting the reflow oven.
                  by bpjl
                  When starting the SEF 551.10 reflow oven, the following problem occurs:
                  It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                  PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                  10-17-2024, 06:30 AM
                • netgearnetgear
                  TOSHIBA 32C100U1 - Faulty display (double images and lines)
                  by netgearnetgear
                  Good day all,
                  I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
                  10-27-2025, 08:07 PM
